20 Most Recent
NEC MobilePro 800 Questions & Answers
Some errors
Download the ATA PCMCIA/CF-Card update drivers* (file name MP8Pcm.exe) from ftp://ftp.necsam.com/pub/versa/mobilepro/. Click on the link to download. After the files are extracted, follow the installation instructions in Readme.txt.
*This module requires 40KB of internal RAM memory. If the MobilePro has been Hard Reset or Main memory has been erased due to main/backup battery low, this module should be re-installed.
Copy of Citrix ICA CE Client
The CE Citrix ICA Client can be downloaded from Citrix.com
* From the "Citrix Downloads" section scroll down until you see "Recommended Client Chart".
* Look for "Windows CE" on the chart.
* Click on "ICA CE Client" to download.
Change the resolution
No. However, you can change the VGA Out from "Display the same image with LCD (640 x 240)" to 800 x 600 or 640 x 480.
Connect to a Windows Terminal Server
Yes. You need to install the RDP client software which can be downloaded from Microsoft.
Procedure to install the RDP client on a MobilePro 880:
Note: Steps 1 and 2 need to completed if you have not installed the Service Pack One for MobilePro 780 and 880.
1. Perform a "Hard" reset on the MobilePro 880.
2. Install NEC Service Pack 1: http://support.neccomp.com/kbtools/faq/mobilepro/mp1.asp
3. Make sure the Device Name is set to something other than "Handheld PC".
1. Start-Setting-Control Panel-Communications
2. Change Device Name to a Unique Name that is not currently being used on your
network.
4. Establish a Partnership with a Host using active sync.
5. Disconnect the MobilePro from the host.
6. Install "hpcrdp.exe" on your host. It can be down loaded from Microsoft:
1. Go to http://www.microsoft.com
2. Select "Search microsoft.com" under the Search tab.
3. Type "hpcrdp" in the search box and depress Enter.
4. Look for the search results titled "Terminal Server Download for Windows CE".
5. Double click on the article and follow the link and at bottom of the Terminal Server License agreement you will find the link to bring down the RDP client.
7. Establish an Active Sync connection between the host and MobilePro 880.
8. The RDP client software will be installed on the Mobile device.
9. Install a NE2000 NIC (or any NIC that you have the MIPS CE drivers for) into the Mobile Pro 880.
10. Set up network and attach to your existing network.
11. Set up a RDP session:
1. Start-Programs-TerminalServerClient-Client Connection Wizard
2. Enter Description connection.
3. Server Name or IP address.
4. Next
5. Enter user name, password and domain if you want to logon automatically.
6. Next
7. Finish
If your terminal server is set up correctly you should be able to connect as a Client.
Error message: "Not enough free space to delete 'filename'"
This error occurs because Windows CE first moves the file to the recycle bin before deleting it, and if there is insufficient space, the error message is displayed and the system appears to hang.
To resolve this issue, use one or more of the following methods.
* Empty the Recycle Bin
Use the following steps to empty the Recycle Bin:
1. Depress the "Alt" key and tap the Recycle Bin.
2. Tap "Empty Recycle Bin"
3. Tap "Yes" when asked to confirm the file deletion.
* Change the Properties for the Recycle Bin so that files are deleted instead of being moved to the Recycle Bin.
Use the following steps to change the properties of the Recycle Bin.
2. Tap "Properties".
3. Tap the check box for "Do not move file to the Recycle Bin, remove immediately on delete".
* To make additional space available for the Recycle Bin.
3. Tap the slider to the right.
Error message: "Unable to establish a secure connection"?
This error can occurs because the VeriSign Certificate Authority (CA) has changed the hashing algorithm that is used for new Secure Sockets Layer (SSL) server certificates from Message Digest 5 (MD-5) to Secure Hash Algorithm 1 (SHA1).
A supported fix is now available from Microsoft for Windows CE 2.11 and Pocket Explorer 3.0 this fix can be found at: http://www.microsoft.com/mobile/handheldpc/downloads/128bit.asp
Note: After you have downloaded and installed the fix, be sure to soft reset the device.
Error message "Not Enough Memory".
The update process failed because the updated GWES.EXE file is in use by the operating system. To correct the situation:
1. Double Tap "OK" to clear the error message.
2. Double Tap "OK" to complete the update process.
3. Double Tap "My Computer".
4. Double Tap "Program File" folder.
5. Single Tap "GWES" ICON while holding down the "ALT" key.
6. Single Tap "Delete".
7. Single Tap "Yes".
8. Perform a "Soft" reset.
Update files be installed
The MobilePro 770/800 update files should be installed in the following order:
1. MP77_UPDATE
2. CE_SP1
3. SCHANNEL.DLL
Memory usage: The three patches use approximately 2,155 KB of storage and 418 KB of program memory.
Patch
Storage memory Program memory
None (hard reset)
323 KB
1,435 KB
MP77_UPDATE
1,016 KB
1,784 KB
CE_SP1
2,380 KB
1,895 KB
Schannel.DLL
2,478 KB
1,917 KB
Available (free)
13,874 KB
14,436 KB
UPDATE.CAB
NEC Computers has developed this update file to address several service issues with MobilePro 770 and 800 handheld personal computers.
To assure proper operation, NEC Computers strongly recommends that you update your MobilePro 770 and 800 systems immediately by installing this file according to the installation instructions.
* Download MP77_Update.CAB for MobilePro 770 and 800:ftp://ftp.neccomp.com/pub/Catalog/4058/MP77_Update.asp
* View Installation Instructions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001313#Installation
* See Contents of MP77_Update.CAB: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001313#Contents
* Read Additional Frequently Asked Questions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001313#FAQ
Installation Instructions for MP77_UPDATE.CAB for MobilePro 770 and 800
First, download MP77_UPDATE.CAB to either your HOST or MobilePro system. It must be manually loaded onto your MobilePro by either using a dial up connection, PCMCIA Flash card, or from a connected PC before continuing with the installation.
To install the MP77_UPDATE.CAB file, follow these steps:
Note: An out of memory error message will be displayed if you attempt to install this file twice.
1. Back up your MobilePro data and configuration using the Microsoft ActiveSync backup procedure. For details on using ActiveSync, see your MobilePro User's Guide.
2. Perform a Soft reset on your MobilePro.
Note: Performing a Soft reset does not erase your data. It simply cleans up the memory and refreshes the system registry.
3. Copy the MP77_UPDATE.CAB file to you MobilePro desktop.
4. Install the file by double tapping the MP77_UPDATE ICON with your stylus. For proper installation, you MUST accept the default location - \Program Files, by clicking OK.
5. Perform a Soft reset on your MobilePro.
6. Once the update file is installed, NECC recommends that you use the ActiveSync backup procedure to again back-up your system. This time your backup will include the update file so you can restore both your data and the update file should either ever be erased.
Contents of MP77_UPDATE.CAB for MobilePro 770 and 800
This file installs updates to the following built-in MobilePro drivers:
* StartUI: This driver eliminates a memory leak that reduces user resources.
* Bitmap files: Replaces an incorrectly sized bitmap file that can cause the unit to lock up if either "the power on password" or "Display Owner Notes features" are enabled for use.
NOTE: NEC Computers strongly recommends that you update your MobilePro 770 and 800 systems immediately by installing MP77_UPDATE.CAB according to the following instructions.
NOTE: During Installation of this file, you must accept the default installation directory or the updates will not be effective!
For assistance or further
What software or cords do I need to get/run in order to get files to transfer to/from the NEC Mobilepro 770, or even get internet?
The NEC Mobilepro 770 is a legacy device that was released in the early 2000s and uses Windows CE as its operating system. Since the device is no longer supported, it may be challenging to find software and drivers that are compatible with modern operating systems like Windows 10. Here are some steps you can take to transfer files and connect to the internet:
- Get the necessary cables: You'll need a USB cable to connect the Mobilepro 770 to your Windows 10 PC. The cable should have a USB Type-A connector on one end and a mini-USB connector on the other.
- Install ActiveSync: ActiveSync is software that allows you to synchronize files between your Mobilepro 770 and your PC. Unfortunately, ActiveSync is no longer available for download from Microsoft, but you may be able to find an archived version of the software on the internet. Install ActiveSync on your Windows 10 PC and connect your Mobilepro 770 to your PC using the USB cable. If the device is recognized, you should be able to transfer files between the two devices.
- Connect to the internet: The Mobilepro 770 has a built-in Ethernet port that you can use to connect to a wired network. To connect to the internet, you'll need an Ethernet cable and a wired network connection. Plug one end of the Ethernet cable into the Mobilepro 770's Ethernet port and the other end into your router or modem. You should be able to browse the internet using the Mobilepro 770's built-in web browser.
- Install additional software: The Mobilepro 770 comes with a basic set of software, but you may want to install additional software to make the device more useful. You can download and install software from the internet, but make sure it's compatible with Windows CE and the Mobilepro 770.
Keep in mind that the Mobilepro 770 is a legacy device, and its performance and capabilities may be limited compared to modern devices. It's also possible that some of the software and drivers you need may no longer be available or supported.
NEC Versa LX Screen will not come on
NEC Versa LX Screen
no model told screen, a monitor is it"?
the 1998 PC that? has no change at all to run
zero.
Pentium II (p2) relic,
no modern OS run on it
the coin cell battery and huge battery are toasted.
hdd is bad.
it has zero value now, and to fix it will be costly .
the CCFL back lamps are dead.
what is there to like, sure free in a garage sale.
zero value. ,try moving from 1998 to 2010 to gain a future.
