20 Most Recent
NEC MobilePro 900c Pocket PC Questions & Answers
Display has become almost illegible
Maybe your Contrast is screwed up. Try soft resetting, then hold "Alt" and the ">" or "<" key at the same time. You can also see if you can turn up the brightness, using the two keys next to the delete key.
Synchronize
not supoported:
http://www.netstumbler.org/f54/belkin-f5d7010-pocket-pc-2002-a-17632/
more info here:
(last message, and check the site)
http://www.pocketpcmag.com/forum/topic.asp?TOPIC_ID=26657&whichpage=2
you need a 16 bit card (available cheap on ebay)
S.
Re newbee
what you mean?if you can buy a mouse for your laptop?
sure yo can buy a usb mouse,that works.
you only have to install the driver,which is mostly in the mouse's package on cd-rom delivered.
lg av
USB Port
Are yous sure it is running CE.NET 4.2? I dont think that the HPC 2000 version can effectively use the USB host. If it is HPC 2000 after all, upgrade the ROM. Try
http://hpcmonex.net/nec900/roms2.html to upgrade your ROM.
NEC mobile pro 900c
Will need to know the brand of your wireless card as it probably needs the driver installed. Hopefully can point you to driver download once know type, version, etc. of wireless card.
Cab files
I found the answer using information in one of the related issues. I installed a custom ROM and all works great now....
Mobilepro 900c Ethernet Card
I use the AVAYA wireless card. It needs to be wireless B. Dowload the driver for it when you sync. Then it should work.
