20 Most Recent
NEC MobilePro 770 Questions & Answers
Connect to a Windows Terminal Server
Yes. You need to install the RDP client software which can be downloaded from Microsoft.
Procedure to install the RDP client on a MobilePro 880:
Note: Steps 1 and 2 need to completed if you have not installed the Service Pack One for MobilePro 780 and 880.
1. Perform a "Hard" reset on the MobilePro 880.
2. Install NEC Service Pack 1: http://support.neccomp.com/kbtools/faq/mobilepro/mp1.asp
3. Make sure the Device Name is set to something other than "Handheld PC".
1. Start-Setting-Control Panel-Communications
2. Change Device Name to a Unique Name that is not currently being used on your
network.
4. Establish a Partnership with a Host using active sync.
5. Disconnect the MobilePro from the host.
6. Install "hpcrdp.exe" on your host. It can be down loaded from Microsoft:
1. Go to http://www.microsoft.com
2. Select "Search microsoft.com" under the Search tab.
3. Type "hpcrdp" in the search box and depress Enter.
4. Look for the search results titled "Terminal Server Download for Windows CE".
5. Double click on the article and follow the link and at bottom of the Terminal Server License agreement you will find the link to bring down the RDP client.
7. Establish an Active Sync connection between the host and MobilePro 880.
8. The RDP client software will be installed on the Mobile device.
9. Install a NE2000 NIC (or any NIC that you have the MIPS CE drivers for) into the Mobile Pro 880.
10. Set up network and attach to your existing network.
11. Set up a RDP session:
1. Start-Programs-TerminalServerClient-Client Connection Wizard
2. Enter Description connection.
3. Server Name or IP address.
4. Next
5. Enter user name, password and domain if you want to logon automatically.
6. Next
7. Finish
If your terminal server is set up correctly you should be able to connect as a Client.
I have A MobilePro 770,
Of course you need to load the software and setup a tcp/ip service.
Consult your service provider and manufacturer of phone.
Sorry.
Please copuld you help me?
you have entered the pin code wrong 3 times now you are required to enter a puk code to reset the pin code.
The puk code is sim card spesific it comes with the sim card when you get it or you can get it by calling your phone service provider of the sim card to get the puk code.
if you have entered the puk code wrong too many times you will make the sim card useless and you will have to contact your phone service provider for a new sim card, it will probably cost.
770 going weird
Could you have an alarm set somewhere? If nothing else, I'd back up and do a hard reset. Might be some programs that are lost - don't know for sure. Anything in the units memory will be lost.
BRAUN shaver Flex intergral 5550
Nothing happen on the LCD of my NEC Mobile Pro 770 and when the technician checked it The flex connector bettween the LCD and the Keyboard was broken. i need to replace it but do not know where to get one. Please inform in case you know.
Thanks a nd regards,
Castro.
Memory card
I use a 6 in 1 scandisk universal adapter that accepts SD and other storage cards. They can be purchased off the internet for about $30.00.
I put in my 1 & 2 gig cards and it works fine
NEC MobilePro 770
These are older devices, and Lihium-Ion batteries degrade from the date of manufacture. You will most likely need to follow instructions (easy to find on the internet) to "fix" the battery. It needs two new cells.
Connection problems
Attach the AC power cord or adjust the power saving mode so the unit does not go into "standby" mode. This is caused by the unit going into "standby" mode when data is being transferred.
Copy of Citrix ICA CE Client
The CE Citrix ICA Client can be downloaded from Citrix.com
* From the "Citrix Downloads" section scroll down until you see "Recommended Client Chart".
* Look for "Windows CE" on the chart.
* Click on "ICA CE Client" to download.
Change the resolution
No. However, you can change the VGA Out from "Display the same image with LCD (640 x 240)" to 800 x 600 or 640 x 480.
Lower fidelity voice recording capability
MobilePro 770 units with a serial number before MC-B004P3US-033 may have a lower fidelity voice recording capability. This may cause voice recognition software to not function properly. This issue is not experienced with new units.
Some errors
Download the ATA PCMCIA/CF-Card update drivers* (file name MP8Pcm.exe) from ftp://ftp.necsam.com/pub/versa/mobilepro/. Click on the link to download. After the files are extracted, follow the installation instructions in Readme.txt.
*This module requires 40KB of internal RAM memory. If the MobilePro has been Hard Reset or Main memory has been erased due to main/backup battery low, this module should be re-installed.
Error message: "Not enough free space to delete 'filename'"
This error occurs because Windows CE first moves the file to the recycle bin before deleting it, and if there is insufficient space, the error message is displayed and the system appears to hang.
To resolve this issue, use one or more of the following methods.
* Empty the Recycle Bin
Use the following steps to empty the Recycle Bin:
1. Depress the "Alt" key and tap the Recycle Bin.
2. Tap "Empty Recycle Bin"
3. Tap "Yes" when asked to confirm the file deletion.
* Change the Properties for the Recycle Bin so that files are deleted instead of being moved to the Recycle Bin.
Use the following steps to change the properties of the Recycle Bin.
2. Tap "Properties".
3. Tap the check box for "Do not move file to the Recycle Bin, remove immediately on delete".
* To make additional space available for the Recycle Bin.
3. Tap the slider to the right.
My MobilePro 770 intermittently stop responding at startup
With the Owner information screen or passwords enabled, it is possible that a deadlock condition can occur as the Graphics, Windowing, and Events Subsystem starts up.
The only work around at this time is to disable the owner information screen in Settings/Control Panel/Owner and/or to disable Passwords in Settings/Control Panel/Passwords.
This information is also found at Microsoft site at: http://www.microsoft.com/technet/ Article ID: Q260315
