20 Most Recent
NEC MobilePro 750 Questions & Answers
Citrix ICA CE Client
The CE Citrix ICA Client can be downloaded from Citrix.com
* From the "Citrix Downloads" section scroll down until you see "Recommended Client Chart".
* Look for "Windows CE" on the chart.
* Click on "ICA CE Client" to download.
Updates for the PCMCIA and Compact Flash Card controllers
Some MobilePro units have exhibited the following symptoms when using Compact Flash Cards or ATA PCMCIA Memory Cards:
1. Storage Card folder is not displayed when you insert a PCMCIA ATA card and/or a Compact Flash card.
2. Warning message "Unidentified PC Card Adapter".
3. Warning message "Storage Card Warning" displayed.
To fix these issues:
If you have a MobilePro 750C without a ROM upgrade, download the file MP75Pcm.exe from support.necsam.com. For a MobilePro 750C with upgraded ROM, use the file MP75RPcm.exe. After the files are extracted, follow the instructions in the Readme.txt file.
External VGA controller
The VGA adapter is only for use with Pocket Power Point:
1. Open a PowerPoint presentation.
2. Go to the View menu and select External VGA on the View Show On drop down menu.
3. To make the presentation display automatically, under Advance Slide choose Automatic and enter in the amount of time in seconds between slides.
4. Say OK to that screen, then go to the View menu again and select View Show and now the presentation should display on the VGA monitor in 640x480 and 256 colors.
Not Enough Memory errors
* Empty your Recycle Bin on a regular basis.
* Delete unused programs and files.
* Reduce the storage space reserved for Internet Cache.
o Open Pocket Internet Explorer (PIE)
o Select View, Options and Advanced.
o Adjust the size of cache, select Empty Cache When Exiting or disable caching altogether by removing the check mark from Enable Caching.
* Consider external storage as an alternative.
Windows CE device
This error occurs because Windows CE first moves the file to the recycle bin before deleting it, and if there is insufficient space, the error message is displayed and the system appears to hang.
To resolve this issue, use one or more of the following methods.
* Empty the Recycle Bin
Use the following steps to empty the Recycle Bin:
1. Depress the "Alt" key and tap the Recycle Bin.
2. Tap "Empty Recycle Bin"
3. Tap "Yes" when asked to confirm the file deletion.
* Change the Properties for the Recycle Bin so that files are deleted instead of being moved to the Recycle Bin.
Use the following steps to change the properties of the Recycle Bin.
2. Tap "Properties".
3. Tap the check box for "Do not move file to the Recycle Bin, remove immediately on delete".
* To make additional space available for the Recycle Bin.
3. Tap the slider to the right.
"Fatal Application Error"
This problem may occur if the user allows the batteries to discharge to a state where the MobilePro must shut itself down. This state may cause the system storage memory to become unstable requiring a "hard" reset after the system has been fully charged again. Failure to perform the hard reset may result in data loss at a later time. The user manual states that if you receive a message indicating that the batteries are low, immediately connect the AC adapter to the device.
The solution is to perform a "hard" reset after fully charging the internal batteries, and then install the service packs, software updates and user software.
What software or cords do I need to get/run in order to get files to transfer to/from the NEC Mobilepro 770, or even get internet?
The NEC Mobilepro 770 is a legacy device that was released in the early 2000s and uses Windows CE as its operating system. Since the device is no longer supported, it may be challenging to find software and drivers that are compatible with modern operating systems like Windows 10. Here are some steps you can take to transfer files and connect to the internet:
- Get the necessary cables: You'll need a USB cable to connect the Mobilepro 770 to your Windows 10 PC. The cable should have a USB Type-A connector on one end and a mini-USB connector on the other.
- Install ActiveSync: ActiveSync is software that allows you to synchronize files between your Mobilepro 770 and your PC. Unfortunately, ActiveSync is no longer available for download from Microsoft, but you may be able to find an archived version of the software on the internet. Install ActiveSync on your Windows 10 PC and connect your Mobilepro 770 to your PC using the USB cable. If the device is recognized, you should be able to transfer files between the two devices.
- Connect to the internet: The Mobilepro 770 has a built-in Ethernet port that you can use to connect to a wired network. To connect to the internet, you'll need an Ethernet cable and a wired network connection. Plug one end of the Ethernet cable into the Mobilepro 770's Ethernet port and the other end into your router or modem. You should be able to browse the internet using the Mobilepro 770's built-in web browser.
- Install additional software: The Mobilepro 770 comes with a basic set of software, but you may want to install additional software to make the device more useful. You can download and install software from the internet, but make sure it's compatible with Windows CE and the Mobilepro 770.
Keep in mind that the Mobilepro 770 is a legacy device, and its performance and capabilities may be limited compared to modern devices. It's also possible that some of the software and drivers you need may no longer be available or supported.
NEC Versa LX Screen will not come on
NEC Versa LX Screen
no model told screen, a monitor is it"?
the 1998 PC that? has no change at all to run
zero.
Pentium II (p2) relic,
no modern OS run on it
the coin cell battery and huge battery are toasted.
hdd is bad.
it has zero value now, and to fix it will be costly .
the CCFL back lamps are dead.
what is there to like, sure free in a garage sale.
zero value. ,try moving from 1998 to 2010 to gain a future.
