20 Most Recent Canon A3300 IS Digital Camera Questions & Answers
When i powted ON the camera that time lense not open. How can i do
change the batteries, if that fails take it to a repair shop
11/12/2014 4:14:59 PM • Canon A3300 IS... • Answered on Nov 12, 2014
On?Off switch failure
Not sure the A3300 has two AA sized batteries, but if it had: Sure your batteries are still tip top? Try two new AA sized NiMH rechargeable batteries or if you have some new alkaline batteries, put them in. the alkaline batteries won't last long, but it it could hint if the camera is still working and worth buying new rechargeables. AA manganese (Zinc-Carbon) batteries cannot be used with this camera. But even if it has one battery, check the battery. Read other parts about batteries, in other help text I wrote for other users.
11/27/2013 11:16:18 PM • Canon A3300 IS... • Answered on Nov 27, 2013
Lens error
Remove the battery and put it back in and restart.
9/17/2013 6:24:36 PM • Canon A3300 IS... • Answered on Sep 17, 2013
Replacement Lense protector shutter spring
Canon
6/4/2013 3:41:44 AM • Canon A3300 IS... • Answered on Jun 04, 2013
Canon A3300 IS lens wont go in or out
take both your fingers lightly push both sides of the lens till its completely in and the lens closes then turn back on it should work I just did this fixed one that was dropped in about 5secs
3/28/2013 5:39:29 PM • Canon A3300 IS... • Answered on Mar 28, 2013
How to fix lens error canon A3300 IS.
Try the procedures in this tip.
9/5/2012 2:16:36 PM • Canon A3300 IS... • Answered on Sep 05, 2012
I have a Canon Power
If you can see past photos on the lcd screen then its probably the ccd that damaged .
It should be still under warranty.
6/9/2011 10:43:28 PM • Canon A3300 IS... • Answered on Jun 09, 2011
I have a new Canon
Insert the card into a card reader and format it on the computer. See if that works. Format using FAT32 as its more reliable than the FAT it uses by default. If the camera supports FAT32 you can expect it to last atleast a year before you need to format it again
5/18/2011 9:08:28 PM • Canon A3300 IS... • Answered on May 18, 2011
My Mac will not install
This must be because you have a widescreen monitor or because you have set a screen resolution that's too low for anything.
Most programs ask for a screen resolution higher than 1024x768 (which they rarely actually need) to install.
So you can change yours to that value (or higher) for the installation and if it distorts your display, set it back to the original value later.
To see how to change your resolution, go to this site; http://www.ehow.com/how_2064940_change-display-resolution-mac-osxchange-display-resolution-mac-osx.html
After setting the resolution to 1024x768 or higher, run the installation and it should proceed with no problems.
5/5/2011 5:56:48 PM • Canon A3300 IS... • Answered on May 05, 2011
Canon 12x36 is ii stabilization is not working properly. Stabilization tends to want to stray.
Hello, I think dust, smudges, or fingerprints on the lenses can affect image quality and stabilization performance. Use a soft, lint-free cloth or lens cleaning solution to gently clean the lenses of your binoculars. Make sure not to apply excessive pressure or use abrasive materials that could scratch the lens surface. Moreover, when using image-stabilized binoculars, it's important to hold them steadily and avoid sudden movements. Rest your elbows on a stable surface or use a tripod if possible to minimize hand tremors. Ensure that you're using proper stabilization techniques to maximize the effectiveness of the stabilization feature.
3/21/2024 12:18:08 AM • Canon Cameras • Answered on Mar 21, 2024
Canon Prima BF-800 Zoom Compact Point and Shoot Zoom Camera. I can't use the date feature?
The date feature has to be set up and there is always a way to turn it off and on. I was looking for a manual, but this is not a North America model. This link might work better for you.https://www.google.com/search?q=canon+prima+bf-800+zoom+manualThe Error Codehttps://www.google.com/search?q=canon+prima+bf-800+zoom+hr+ha+errorMake sure the batteries are good!..
2/18/2024 8:48:21 AM • Canon Cameras • Answered on Feb 18, 2024
I have problem with my canon a95 a Change battery but still my camera say me to change a battery
If you are using Nickel Metal Hydride rechargeable batteries, they have come to the end of their lifespan. Buy New or use AA Lithium batteries. https://www.google.com/search?q=canon+a95+battery ..
2/15/2024 10:55:54 PM • Canon Cameras • Answered on Feb 15, 2024
My Canon AV1 only shoots in B mode, the light meter works correctly, and everything else seems fine. Has anyone had the same issue and found a solution?
If your Canon AV-1 is only shooting in Bulb (B) mode, it could be due to a malfunctioning shutter or aperture control. However, since the light meter is working correctly, it is possible that the issue is with the camera's shutter speed dial. The shutter speed dial is located on the top of the camera and should be set to a specific speed when shooting in aperture-priority mode. If the dial is stuck in the Bulb (B) position, then the camera will only shoot in bulb mode. I would recommend taking your camera to a professional camera repair shop to have it inspected and repaired if necessary.
1/21/2024 11:01:27 PM • Canon Cameras • Answered on Jan 21, 2024
Any instructions about repairing Canon Legria HF200?
Real help that is not AI Generated! Articles and instructional videos https://www.google.com/search?q=canon+legria+hf200+clean+lens+and+sensors ..
12/30/2023 9:14:41 PM • Canon Cameras • Answered on Dec 30, 2023
2answers
Canon PowerShot G5 Camera. Can the LCD screen on the Canon G5 be repaired of replaced?
Yes of course. Take it to your local Canon Service Centre. https://www.google.com/search?q=Canon+Camera+Service+Centre ..
12/14/2023 11:09:56 PM • Canon Cameras • Answered on Dec 14, 2023
Best canon ef lens for a canon rp with ef-rf adapter.
Ef85 f 1.8 ISNT to bad fun cheap lens can be a 50mm f 1.8
12/10/2023 9:59:05 AM • Canon Cameras • Answered on Dec 10, 2023
Why wont my 2gb sd card work with my Canon zr200
card max is 8 mb https://www.manualslib.com/manual/24534/Canon-Zr200.html?page=90#manual
10/20/2023 4:59:29 PM • Canon Cameras • Answered on Oct 20, 2023
Hi, My Canon Powershot A480 camera keeps on scrolling by itself
i kindly advice you restart the camera ,it may fix the problem,.Also ensure on the camera's buttons or around the scroll wheel there is no dust .If it persist try to reset factory the camera
9/21/2023 2:54:45 PM • Canon Cameras • Answered on Sep 21, 2023
Canon A3300 IS Digital Camera Logo
18 questions posted
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
Canon Cameras
  • Canon Cameras
Most Popular Question
off switch failure
  • Cameras
