20 Most Recent
Raymarine ST6001 S1G Hydraulic GPS Receiver Questions & Answers
Raymarine C70 MFD wont 'Restart GPS'
Perform a factory reset: If your Raymarine C70 MFD is not responding, you can try performing a factory reset. This will restore the device to its original settings and may resolve the issue. To perform a factory reset, follow the instructions provided.
Factory Reset procedure for a A/C/E-Series Classic Multifunction Display (raymarine.com)
Check GPS source: It's possible that there's some confusion in the system configuration about what GPS source is in use, and this might cause your false Route Complete alert. You can check what's shown in Home > Settings > Network > Data Sources on the Master display.
Update software: If the above steps do not work, you can try updating the software of your Raymarine C70 MFD. You can download the latest software update files from
C Series Classic Software ' Raymarine
Charts won't load on raymarine e80 chart plotter
If you are having trouble loading charts on your Raymarine E80 chartplotter, there are several things you can try to troubleshoot the issue:
1. Check the chart card: Make sure that the chart card is inserted correctly and that it is compatible with your chartplotter. Some chartplotters require specific types of chart cards, so check the user manual or contact the manufacturer to ensure compatibility.
2. Check for software updates: Make sure that your chartplotter has the latest software updates installed. You can check for updates on the Raymarine website or by contacting customer support.
3. Check the chart source: Make sure that the chart source is set correctly on your chartplotter. If you have multiple chart sources (e.g. internal memory, external card), make sure that the correct source is selected.
4. Check the chart format: Make sure that the chart format is compatible with your chartplotter. Some chartplotters only support certain chart formats, so check the user manual or contact the manufacturer for compatibility information.
5. Check for obstructions: Make sure that there are no obstructions blocking the GPS antenna or interfering with the chartplotter's reception. Obstructions can include tall buildings, trees, and other objects that block the line of sight to the GPS satellites.
6. Reset the chartplotter: Try resetting the chartplotter to its default settings. This can sometimes clear up software glitches or other issues that may be preventing the charts from loading.
If none of these solutions work, you may need to contact Raymarine customer support for further assistance or repair.
Take care and have a great day! -Alex
Radar Raymarine HD wiring diagram, how to wire to Raymarine C120 unit
After nearly 4 years I dunno if you got this sorted.
The question is ambiguous, as Raymarine radar comes with wiring harnesses; the display end is a plug-and-play 12-pin male to the harness end female; the other end goes up the mast in a plastic sleeve to prevent damage to the 8-pin connector and the 2 or 4 power cables (depends on "light" or "heavy").
There's a means of connecting a digital radar to the C120 but I don't have that so don't know the specifics.
Is this the sort of information you were looking for?
