20 Most Recent
Raymarine E120 Multifunction GPS Receiver Questions & Answers
Connect an raymarine E120 Display to the RNS software in a PC
Try a cross over network cable from the PC to the E-Series. Raymarine Made each one of their cables as a straight cable so you would need to buy the cross over coupler or network switch box to use it with another unit. It's nothing different from normal networking with the exception that they have removed wires 4,5,7 & 8 from the cable and it's a straight. Give that a try.
My Raymarine E-120 started blinking
Check your voltage. Low voltage can cause the screen to flicker, freeze up, and power off and on. Just because it powers up does not mean you have the correct voltage. This is hard on equipment. Don;t check at the battery, check on the power cable to the E-series.
I get a message indicating the track memory is
Memory all your Track ,waypoint , route on a empty CompaktFlash card. This is how its go
Insert a EMPTY card press DATA than ARCHIVE AND TRANSFARE than SAVE TO CARD choose what you want to save or save all.
Make a Factoryreset on your E120.
Your Software shoud be 5.23.
Put in your CompaktFlashcard with the DATA and choose what you want in your E 120
Dsm connection lost radar not turning
-Measure if you DSM has power.
-Maybe you Radar needs Power it depend on wich typ of Radar you have
-Software shoud be 5.23 of ALL your E Displays
- If you have a Networkswitch measure if you have power.
Problems talking to autopilot
I think you use the NMEA output to the autopilot .
The plotter shows you only when you have a seatalkconection with a Raymarine autopilot on you Plotter
Raymarine e series malfunction
I have found that many of the issues you are experiencing are a result of operator error (no offense). For the system you have described, you will definitely have a network switch which interfaces everything. Is it possible that the network switch is powered from a source that you dont always turn on? In other words, if the system has multiple breakers and the network sw is tied to one of them, using only one display for example may leave the switch without power and give the error messages you described. Bottom line......BE SURE that the entire system is powered on. Another possible cause is master vs slave. One of the two displays is the master. If you power the system up in the wrong order or without the network switch in the loop, the slave unit will automatically ask you to set it as the master. NEVER do this. Changing the master will result in data loss as you described. Finally, if all of this checks out, verify the software in your displays (the version will appear in the bottom right during start up). Your software should be at least V4.29 but there is a newer version available so if you need to upgrade make sure you get the most recent. Good luck
Our e120 has no boat recognition. We cannot make
Do you have fix on the GPS?
Have you selected "find boat" and not "cursor" (bottom left button under the screen)? If you'r still stuck try a master reset (factory reset) by going into the menu and select system setup - factory reset.
Raymarine G-series. How do you reset. We have
Call Raymarine Tech Support or your installing dealer. The G series equipment is the cream of the Raymarine crop and troubleshooting it is not common knowledge even for dealers. Get your info right from the horse's mouth.
Raymarine C70 MFD wont 'Restart GPS'
Perform a factory reset: If your Raymarine C70 MFD is not responding, you can try performing a factory reset. This will restore the device to its original settings and may resolve the issue. To perform a factory reset, follow the instructions provided.
Factory Reset procedure for a A/C/E-Series Classic Multifunction Display (raymarine.com)
Check GPS source: It's possible that there's some confusion in the system configuration about what GPS source is in use, and this might cause your false Route Complete alert. You can check what's shown in Home > Settings > Network > Data Sources on the Master display.
Update software: If the above steps do not work, you can try updating the software of your Raymarine C70 MFD. You can download the latest software update files from
C Series Classic Software ' Raymarine
Charts won't load on raymarine e80 chart plotter
If you are having trouble loading charts on your Raymarine E80 chartplotter, there are several things you can try to troubleshoot the issue:
1. Check the chart card: Make sure that the chart card is inserted correctly and that it is compatible with your chartplotter. Some chartplotters require specific types of chart cards, so check the user manual or contact the manufacturer to ensure compatibility.
2. Check for software updates: Make sure that your chartplotter has the latest software updates installed. You can check for updates on the Raymarine website or by contacting customer support.
3. Check the chart source: Make sure that the chart source is set correctly on your chartplotter. If you have multiple chart sources (e.g. internal memory, external card), make sure that the correct source is selected.
4. Check the chart format: Make sure that the chart format is compatible with your chartplotter. Some chartplotters only support certain chart formats, so check the user manual or contact the manufacturer for compatibility information.
5. Check for obstructions: Make sure that there are no obstructions blocking the GPS antenna or interfering with the chartplotter's reception. Obstructions can include tall buildings, trees, and other objects that block the line of sight to the GPS satellites.
6. Reset the chartplotter: Try resetting the chartplotter to its default settings. This can sometimes clear up software glitches or other issues that may be preventing the charts from loading.
If none of these solutions work, you may need to contact Raymarine customer support for further assistance or repair.
Take care and have a great day! -Alex
