20 Most Recent
Husqvarna Chain Saw Models 51, 55 Questions & Answers
Husqvarna 51 file size
Several bar and chain combinations fit the 51 model saw. If your saw runs an H46 / H80 or H81 style chain you will need a 7/32" (5.5 mm)
If you are running a H21 style chain you will need 3/16" (4.8mm)
Why wont my saw fire the sparkplug with the replacement coil
Make sure you are using a resistor plug. This is extremely important on this model. If this is not the issue, remove coil, use emory cloth to clean the mounting area for the coil. Trash or oxidation can prevent a good ground on the coil. Lastly make sure the air gap (distance from flywheel to coil is correct) itshould be .012"
What is the gas/2 cycle oil mixtuure for a husqvarna 55 chainsaw
These saws were normally ran on a slightly richer mix. The reason was becuase of the mix oil available. I would recommend running a 40:1 or 50:1 mix. Make sure you use an "FD" rated mix oil and Premium ethanol free fuel.
The premixed fuels / oils are even better. They contain the FD rated oil 95 octane fuel and no ethanol.
Trouble starting
You should check the carburetor to see if you don't have any vacuum leaks or gas leaks. You may have to replace the gasket under the carb. Before doing that , check to see if your choke is working right.Also check the filter and hose inside the gas tank to see if they are good. The filter unclogged and the hose not leaking.
If it is none of the above, the carb probably gave out. You may need a new one.
Hasqvarna mod 55 pull cord will not rewind. How do
The 55 spring is supplied in a black plastic keeper, its just a matter of removing the centre screw, remove the pulley, the spring is then captive in the keeper, carfully ease out ( always wear saftey glasses ) you can now drop the new spring in.
Coil failure or not?
In my experience you can do all the testing you like, but if the coil does not perform properly on the machine then it requires replacment
