20 Most Recent
True TSSU-48-12 Refrigerator Commercial Questions & Answers
The fridge to begin with was extremely cold
The symptoms are consistent with a bad thermostat. Start with being sure fans Inside and at the Compressor are running and if so replace the thermostat, if the unit still malfunctions, you'd need a refrigeration tech. That altitude won't make any difference. The Salad top units are just fine up to 7000 feet ASL no problem.
The True brand commercial refrigerator
You will need to adjust the thermostat.
The thermostat will be hidden at the bottom back of the fridge near the compressor.
You may need a screw a flat blade driver driver to adjust the themostat
REPLACE HINGE
This hinge is a cartridge and the bottom hinge has to be removed to replace it, then you just unscrew the cartridge and change it out, it's pretty simple.
Compressor runs continuously freesing foods.
Yes for sure it is the thermostat but whether the unit has failed or if the controller is faulty or a wirelink had cut off is to be found out with a detailed check.
Look from the controller and see the sensor, if intact and at lower settign of temperature the compressor does not cut off, the thermostat is faulty.
