20 Most Recent Apple Ipad I-pad Questions & Answers
How do I delete old flyclops domino game on iPad?
There are different ways to delete old flyclops domino game on iPad. However, the easiest way is through tapping and holding. Just follow the below steps to do that. How to Delete Games on iPad through Tapping and Holding Maybe the space in your iPad is not enough to let you enjoy all of the great iOS gaming to the fullest. Get rid of the one you have enjoyed and keep looking for the new choice is what a smart game player needs to do. All you need is just a few moves. Now follow me to see how to delete games on iPad through tapping and holding. Step 1: Find the game you want to delete. Touch and hold it until a cross icon appears on the top left corner of the icon. Step 2: Click the small crosses to delete the games. Now all the data has been deleted on your iPad. How to Delete Games on iPad via Setting App You can also delete games on iPad through setting app. I am going to help you make clear of how to delete games on iPad via setting app. Step 1: Click setting app on your iPad. Choose "General" and then click the game you would like to erase. Click "Delete App" to erase all the data out of your iPad. Now you know How to Delete Games on iPad through setting app. For more details, check: How to Delete Games on iPad
8/22/2019 7:06:03 AM • Apple Ipad I-pad • Answered on Aug 22, 2019
I pad actativion lock is on forgot password
If you have backed up iPad, just restore iPad to factory settings and then recover data from the backup. Follow below steps to reset the password on iPad. If you haven't synced your iPhone with iTunes before or if you haven't enabled your Find My iPhone on, you can take advantage of the third method. Resetting iPhone Password in Recovery Mode is not complicated. The steps below will show you how to do that. Step 1. Disconnect all cables from your iPhone and turn it off. Step 2. Press and hold the Home button and connect your device to iTunes. If your iPhone does not turn on, please turn it on manually. Step 3. Continue holding the Home button until you see the Connect to iTunes screen. iTunes will remind you that it has detected your iPhone in recovery mode. Step 4. Click OK. The Summary tab in iTunes appears. Click "Restore iPhone" and restore your iPhone. Recovery Mode will erase all your data and passcode from your iPhone, resetting it to factory defaults. Thus, you'll have brand new iPhone without any personal data after you reset iPhone password with Recovery Mode. Therefore, please consider carefully whether you need to use this method to reset password on iPhone. If you remember your current iPhone password and you just want to change into a new password, you can finish it with ease. Go to Setting > General > Touch ID > Passcode (iOS 9/8/7) or Passcode Lock (iOS 6), then enter the current password and tap Change Passcode. Then enter the new passcode. Now, you have reset your iPhone password. For more methods, check: How to Reset Password on iPhone
8/22/2019 7:00:23 AM • Apple Ipad I-pad • Answered on Aug 22, 2019
How to unlock ipad forgot passcode
You can restore your iPad through iTunes or iCloud to reset the passcode. Just follow below steps to make it. If Find My iPhone app is on, you can try the socond method: Reset iPhone password with iCloud Find My iPhone. The detailed steps are shown as below. Step 1. Go to icloud.com and log in with your Apple ID and password on your computer. Step 2. Click Find My iPhone. Then click All Devices at the top of your browser window. Step 3. Select your iPhone from all the devices listed. Click Erase iPhone to erase your iPhone along with its passcode. Step 4. Use the Setup Assistant on your device to restore the most recent backup of your device. After the restoration process is finished, your passcode will be erased and all your data will be restored from your iCloud backup. You will now be able to access your iPhone without any passcode. For more methods, check: How to Reset Password on iPhone
8/22/2019 6:53:27 AM • Apple Ipad I-pad • Answered on Aug 22, 2019
How do you by pass password on I pad ?
If you want to bypass password on iPad, you have to reset the password through iTunes/iCloud or the 3rd-party tools. Just follow below steps to do that. If you have synced your iPhone with iTunes before you forget your iPhone password, you can reset your iPhone by using iTunes without losing data. Through iTunes, you can restore your iPhone from the last backup and remove the passcode from your locked iPhone while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPhone Passcode with Recovery Mode section below. The following steps will show you how to reset iPhone password with iTunes. Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted. Step 2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required. Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by in the Summary window. Step 4. In the Summary window, you can see the option "Restore iPhone". Click it and follow prompts to choose the latest iTunes backup to restore your iPhone. After the restoration process is complete, your passcode will be erased and all your data will be restored from your backup. You will now be able to access your iPhone without any passcode. And you can set your new password on iPhone. For more methods, check: How to Reset Password on iPhone
8/22/2019 6:51:39 AM • Apple Ipad I-pad • Answered on Aug 22, 2019
MY IPAD IS IN RECOVERY MODE
If you're stuck in Recovery Mode, you can follow below steps to exit this mode with ease. When your iPhone get stuck in recovery mode, the most recommended way to solve this program is to restore your device with iTunes. It works most of the time but you might lose some of the data on your iPhone. Step 1. Open iTunes and connect your iPhone to your PC with USB cable. A popup would show up. Click OK. Step 2. Click the iPhone icon on the upper left corner to open Summary tab. And then click Restore iPhone. Step 3. On the following popup, click Restore to confirm that you want to exit recovery mode by restoring your iPhone to factory settings. Step 4. When the restoring process is done, you can click Restore from backup to select an old backup of your iPhone in iTunes and load the data back to your device. For more details, check: Methods to Help iPhone Exit Recovery Mode
8/22/2019 6:48:22 AM • Apple Ipad I-pad • Answered on Aug 22, 2019
Need ios6 & 7 updates
There are lots of ways you can try to update iOS6 & 7 to latest version. Follow one of them. If a message says that an update is available, you could then click "Install Now" button to start to update your iPhone iOS software. Also, you could manually check whether there is an iPhone iOS update or not on your iPhone. The below steps would show you how to update iPhone software wirelessly:
  1. Before you update iPhone software via WiFi connection, you need to make sure your iPhone has enough storage and battery to support the iPhone update.
  2. Connect your iPhone to a WiFi network.
  3. Tap "Settings > General > Software Update" successively.
  4. Tap "Download and Install" option when your iPhone has detects an update available. If a message asks to temporarily remove apps because iOS needs more space for the update, tap Continue or Cancel. Later, iOS will reinstall apps that it removed.
  5. Then iPhone would start to download and install iOS update immediately. You only need to wait for the update complete.
For more methods, check: How to Update iPhone
7/2/2019 5:47:40 AM • Apple Ipad I-pad • Answered on Jul 02, 2019
3answers
Can I read kindle book downloads on my I pad? And if so how do I access them?
first you need to download the Kindle App from the App-store 25722009-cjwv3quepw01npndmt4asrxe-3-0.jpg 25722009-cjwv3quepw01npndmt4asrxe-3-2.jpg How to Manually Add Kindle Book to Your iPad or iPhone
5/31/2019 3:53:53 AM • Apple Ipad I-pad • Answered on May 31, 2019
Candy troubleshooting candy crush wheel not working? Pop-up tells me I need Facebook. I don't have Facebook nor do I want it.
uninstall candy crush then re-install candy crush
1/13/2019 5:35:32 AM • Apple Ipad I-pad • Answered on Jan 13, 2019
2answers
Why won't my messages send
Could be several things - is her number correct? Is is entered correctly (no extra characters)? Do you have iMessage set up correctly? Apple will try to use iMessage if it can even if you are sending a SMS http://www.imore.com/daily-tip-setup-imessage-ipad
1/13/2019 3:25:04 AM • Apple Ipad I-pad • Answered on Jan 13, 2019
tip
Using an alias email with GMail in iOS 10 (iPad and iPhone)
A relative using an iPad (iOS 10) wanted to use an alias e-mail with his GMail account but iOS 10 appears to have removed the functionality which is still available in macOS. A solution is suggested at on the Apple discussions pages (Creating email alias in iOS 10 no longer possible ) but here I give step-by-step details (I don't have an Apple ID so I couldn't post this in the Apple discussions forum) Preliminaries: I'm assuming the user has a gmail address [email protected] with password pwd1 and 2-step-authentication enabled in GMail (have your mobile with you!) The user wants the sent e-mails to appear to come from [email protected] The process involves setting up the GMail account twice on the iPad:
  1. once using the iPad built-in GMail setup, for Calendar, Contacts
  2. once using the iPad Other mail service setup, for Mail
1. In Settings go to Mail, add an Account; select GMail and follow the prompts... this sets up Mail to use GMail mail, calendars and contacts (and optionally to stored Apple Notes on GMail) for [email protected]. Later on we will switch off mail as it will be duplicated by the following IMAP account. 2. In Settings go to Mail, add an Account; this time select Other as the mail provider:
a) Fill in the dialog entries: Name: the user's name; Email: [email protected] Password: get this password from Google using App password feature (Sign in using App Passwords -- note you will need your mobile; this is a 16-character password) and write it down as you will need it again later; Description: you can call this GMail mail only for now b) Click Next and enter the following information Name: should be prepopulated as above Email: should be prepopulated as above [email protected] Description: should be prepopulated as above GMail mail only Incoming mail server (as per Read Gmail messages on other email clients using IMAP): Host name: imap.gmail.com Username: user.name Password: the 16-character password generated by GMail App password above Outgoing mail server (as per Read Gmail messages on other email clients using IMAP): Host name: smtp.gmail.com Username: user.name Password: the 16-character password generated by GMail App password above Use SSL: yes Authentication: password Server port: 587 After entering all this information, Mail should connect to GMail and verify the credentials; if correct, it will show blue ticks against the Email, Incoming and Outgoing details. If not then it will display a message saying it could not use the credentials. After doing this, you should have two accounts (in addition to a possible iCloud email account): GMail and GMail mail only; GMail handles Contacts, Calendars and GMail mail only for Mail only. You can check this and then rename GMail mail only to GMail as Mail accepts two accounts with the same name. Now if you want to write an e-mail which appears to come from [email protected] you can select that as the From address: either in the e-mail itself if you have multiple e-mail accounts, or in the Composing settings of Mail. Test this by sending a couple of e-mails. Note: if you have an iCloud account, when that is the current inbox in Mail, new emails will be sent with the iCloud. When the GMail account is the current inbox in Mail, the new emails should be sent with [email protected] if set up that way. HTH someone... until the next iOS or GMail change breaks something else ;-o
on Feb 16, 2017 • Apple Ipad I-pad
How do I enable documents & data in iCloud to be able to attach documents to email
You will need to ensure that you have enabled Desktop & Documents: From your Mac, go to the Apple menu > System Preferences > iCloud.
  1. Make sure that iCloud Drive is turned on.
  2. Next to iCloud Drive, click Options.
  3. Choose Desktop & Documents Folders.
  4. Click Done.
12/5/2016 12:30:58 PM • Apple Ipad I-pad • Answered on Dec 05, 2016
4answers
How to turn off private browsing. Can't get on my email.
I hope you found out how this works already. If not here's what Apple wrote about it: (From https://support.apple.com/de-de/HT203036 ) Turn off Private Browsing On an iPhone, iPad, or iPod touch, open Safari, then tap the icon for tab-overview (two overlapping pages). Tap Private to turn private browsing off. If you're using iOS 7 or earlier on an iPad, open Safari, tap + to open a new tab, then tap Private.
11/20/2016 9:19:26 AM • Apple Ipad I-pad • Answered on Nov 20, 2016
0answers
How get rid of advertisements on my ipad2.
Try using Firefox on the iPad. In its settings, you can have it block pop up windows. You can also try using its private tab feature.
10/12/2016 10:52:32 PM • Apple Ipad I-pad • Answered on Oct 12, 2016
My Apple i pad will not recognise my Wi-Fi password
what type of WIFI device are you using? is it 4G battery powered Huawei make WIFI Device?
10/3/2016 7:52:54 AM • Apple Ipad I-pad • Answered on Oct 03, 2016
Apple Ipad I-pad Logo
646 questions posted
Popular Products
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Apple Cell Phones
  • Apple Cell Phones
Most Popular Question
get rid advertisements ipad2
  • Cell Phones
