20 Most Recent Apple iPhone 4S Questions & Answers
JUST RESTORE YOUR PHONE IN DFU MODE WITH LATEST UPDATE
ALL DATA WILL BE LOST SO BE SURE TO BACKUP ALL
FOR DFU MODE
CONNECT YOUR PHONE TO PC
HOLD POWER + HOME BUTTON WHEN SCREEN GOES OFF
COUNT UPTO 6 AND RELEASE POWER BUTTON WHILE HOLDING HOME BUTTON
Apple iPhone 4S | Answered on Jun 19, 2019
If you go to
https://support.apple.com/en-gb/HT204306
it will explain the ways of deleting your data and passcode.
Here you go everything you need to get you out of the mess :)
http://www.everymac.com/systems/apple/iphone/iphone-troubleshooting-repair-faq/iphone-how-to-unlock-open-forgot-code-passcode-password-login.html
Apple iPhone 4S | Answered on Jun 18, 2019
How to deactivate old iPhone Here we will introduce you four ways of how to deactivate old iPhone and make your personal information keep secured.
Use iOS to reset iPhone
1. Tap on "Settings" from home screen on your iPhone and enter "General". Scroll down to the bottom of the device's screen.
2. Tap on "Reset" and there are several options displaying on the screen.
3. Select the option "Erase All Content and Settings". Then, a prompt will ask you to enter your iPhone's Apple ID along with passcode. All the data, the information, as well as the settings on your iPhone, will be removed by this operation, which includes the feature "Find My iPhone Activation Lock" on iOS 7. Restart your device after the erasing, the prompt "Slide to Set Up" will be displayed on the screen.
Use iTunes to restore iPhone
1. Tap on "Settings" on your device and enter "iCloud". If the feature "Find My iPhone" has been enabled on your iPhone, switch it off by toggling the button to the disabling position. Then enter Apple ID and passcode of your iPhone and tap on "Turn Off".
2. Run iTunes on computer and associate your iPhone with the computer via USB cable. Select your device in iTunes window.
3. Click on "Restore iPhone" from the Summary. Then choose the option "Restore" and confirm you would like to get your iPhone's factory settings reinstated. Your iPhone will restart after the erasing, the prompt "Slide to Set Up" will be displayed on the screen.
Use iCloud to wipe iPhone in a remote way
1. Get access to iCloud.com on your computer web browser. Enter the Apple ID that you use for the service of iCloud on your iPhone. Then Tap "Find My iPhone".
2. Choose your iPhone in the drop-down menu "All Devices" in order to show the information screen of iPhone.
3. Tap "Erase iPhone" from the information screen and enter your Apple ID and passcode in the prompt. If your iPhone is running base on iOS 7 system or later, a phone number and a message must be entered to show up on the device's screen when your iPhone is erased. Wiping in a remote way will be done at once on the iPhone which is online, or the iPhone will effectively become deactivation when it pops up online. Check the email to confirm the erasure on the email address with your Apple ID.
Get rid of the SIM Card
1. Get the SIM tool with pointed end inserted into the hole beside the tray of SIM card, then eject the tray by pushing it.
2. Pull out the SIM card tray and get rid of the SIM Card.
3. Push the tray back to iPhone till a clicking noise can be heard.
use-ios-to-reset-iphone-1-cmgtsts4wenzljgge1wveyvz-2-0_0.jpg For more details, check: How to Deactivate Old iPhone
Apple iPhone 4S | Answered on May 21, 2019
If you have back up your text messages, you can restore from the backup.
To restore information from a backup, use one of the following methods after connecting your iOS device to the computer with which you normally sync:
1. Right-click (or Control-click) the device and choose Restore from Backup
2. If you have a new phone, you can connect to iTunes and it will prompt to restore from your backup
Solution from Apple.com: http://support.apple.com/kb/ht1766
If you have no backup for your data on iPhone, iPhone data recovery software is your last shot! I used Tenorshare iPhone Data Recovery and it worked well. Download it from http://www.any-data-recovery.com/product/iphone-data-recovery.html It's easy to use. Just a few clicks you can get all your data back.
Solutions from iPhone SMS Recovery
How to Recover Deleted Text Messages from iPhone
Apple iPhone 4S | Answered on Jan 27, 2019
Before finding ways to restore or find back your contacts, you'd better to have a look at your Android device, because your contacts might not be deleted. So you need to make sure all your contats are being displayed.
Let's check it as follows:
1. Find "Contacts" and open it on your Android phone.
2. Tap on the menu button on the top right corner. Then choose "Settings" > "Contacts to Display".
3. Select "All Contacts". Now, you can return and check whether you got your contacts back or not.
An excellent program is required for the task - MobiKin Doctor for Android (Win/Mac). It is easy to manage as you can recover lost, deleted, or formatted contacts on Android phones through only several clicks.
How to Recover Deleted Contacts from Android? Step1: Run the Software and Connect Your Phone to Computer
c7af0748c8b6d069eecfccba2e0f8315-uwkecbqhxdnurjdgs33nmwp2-1-0.jpg Step 2: Scan Contacts Deleted on Your Android Phone
Step 3: Preview and Retrieve Android Contacts Selectively
A YouTube Guide for you:
How to Use MobiKin Doctor for Android
Plug your iPhone into a USB connection on your PC. Give it a minute.
- Your iPhone will ask if you want to allow this device (your PC) to access your photos. Click ALLOW.
- Go into Windows Explorer and your iPhone will be there. - Click on it and there will be a DCIM folder. Click on that folder.
- You will find one or more folders under DCIM. Each of these contain the photos on your iPhone.
- COPY (DO NOT MOVE) these from your iPhone to your Computer's desktop. Now you have all photos on your computer and you can safely wrestle with restoring your iPhone.
I hope this response helps you out.
I wish you the very best of luck! If I can help you further, please let me know.
If I've assisted you, I'd greatly appreciate you taking the time to provide me with a favorable rating. Thanks so much!
Apple iPhone 4S | Answered on Jan 23, 2019
That's a VERY old device you're looking for. However I was able to find several available for sale on Amazon (https://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias%3Daps&field-keywords=iPhone+4S). I would strongly encourage you to look for a newer device as a 4S may soon become unsupported. Best of luck!
Apple iPhone 4S | Answered on Jan 02, 2019
If you already have an iCloud account, you should be fine.
Just restore you iphone with icloud and you will have all your contacts again.
if not, check if you got contacts on your SIM card. To do that, go to settings, Mail and contacts and choose import SIM contacts.
If you have a google email adresse set up in your phone, you can recover them from gmail.
hope i helped you
Apple iPhone 4S | Answered on Dec 12, 2018
Hope you can restore those from your backup on iTunes
Apple iPhone 4S | Answered on Oct 25, 2018
have you had a fire or burglar alarm fitted recently? the signal emitted (even when off) can scramble the wi-fi.
Apple iPhone 4S | Answered on Jun 15, 2018
The questions should be questions that only you know the answers to. How can you fail? They only give you questions that you put in the answer.
Apple iPhone 4S | Answered on Jun 11, 2018
You did not describe exactly how it is broken, but assuming it is a hardware issue (physically broken) you can contact apple repair.
Here is their repair page;
https://www.apple.com/support/iphone/repair/
Apple iPhone 4S | Answered on Apr 14, 2018
You can block any number on your iPhone by just installing an app called "iBlacklist"
There you have many options, and with them there's an option of blocking a cellphone number.
You go to Blacklists - General BL. There you have '+' in upper right corner. From there you can add the number you want from contacts, recent calls and messages or write it yourself.
Apple iPhone 4S | Answered on Mar 26, 2018
Hi, This is probably too late but I really hope this can help you or others.
FoneDog - iOS System Recovery
software is the easiest solution so far that we put it on top to let you know that FoneDog - iOS system recovery fixes error 3194 without any data losses and compatible with all iPhone models, iPads and iPod Touch. Here are the steps on how to use FoneDog Toolkit:
Step 1: You need to Download, Install and then Launch FoneDog -iOS System Recovery software
Step 2: Make sure that FoneDog - iOS system recovery detected your iPhone
Step 3: Proceed to "System Recovery"
Step 4: Confirm device in System Recovery module
Step 5: When the download is complete, the repair process starts
Step 6: You are good to go
More information you can see: How to Fix iTunes Error 3194 or iPhone Error 3194
Hope it can help you! How to Fix iTunes Error 3194 or iPhone Error 3194
Apple iPhone 4S | Answered on Mar 19, 2018
It is easy to transfer contacts from Samsung to iPhone using a third-party Phone Data Transfer. In the video below, you will find a reliable tool that helps you make the transfer easily.
Hello Pat, here's a guide to help you delete multiple contacts from your iOS devices. How to Delete Multiple Contacts on iPad
Not very sure if it's able to remove all contacts at once.
Apple iPhone 4S | Answered on Jan 12, 2018
hard reset it, go to www.hard-reset.com
Apple iPhone 4S | Answered on Jan 11, 2018
Apple iPhone 4S Logo
1,116 questions posted
Popular Products
Top Apple Cell Phones Experts
jacobcheatha
Level 1 Expert
Marvin
Marvin
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
iPhone Apple
  • iPhone Apple
Most Popular Question
error 3194 when try restore or update
  • Cell Phones
