[1]Try a new channel, if OK, then
possible station trouble.
[2] Check the antenna connected to terminal on
the back of the set for any loose contact.
[3] If outside antenna is being used,
check for broken wire.
[4] Adjust COLOR control.
[5] Unplug the TV and plug it in again
after two minutes. This process will reset your TV.
If nothing helps, the set's chroma secion should be checked with. The tuner inside it is weak, this problem will occur too. Anyway, if these does not helps you; your TV need service. The exact fault can be detected afterwrds.
Then about the user manual:
I've the user manual for SHARP - 25N-M100. User manual for 25KS100 and 25N100 are the same. If you want it, send your email address to me by FixYa comment box. I'll send a copy of it to you by return mail. As you know, I can't send PDF files by this window. OK.
17 questions posted
878 Questions
339 Questions
295 Questions
241 Questions
228 Questions
