20 Most Recent Neff Appliances Series 1 U17M42 Stainless Steel 60 cm Double Built-in Electric Fan Oven 45 l 30 l, A Energy Rating Questions & Answers
Whirlpool Range Model WBP 34500. I need a wiring diagram for it please?
Unfortunately not for that model. I realize this is an old question but it is stuck and needs answering to get rid of it. :>D https://www.google.com/search?q=Whirlpool+Range+WBP+34500+wiring+diagram ..
4/9/2024 5:46:28 AM • Kitchen Ranges • Answered on Apr 09, 2024
Sirius SU1 Wall Mount Chimney Range Hood, 600 CFM. Not working at all. Replaced board?
It sounds like your new board is faulty or there are bad connections to and from it. Have you asked Sirius Helpdesk Support? https://www.google.com/search?q=Sirius+SU1+no+power ..
3/25/2024 11:28:36 PM • Kitchen Ranges • Answered on Mar 25, 2024
I am looking for a thermostat for my Samet gas stove. Having difficulty to find the part. Any replacements that might also work?
send me a picture of the thermostat body and i may be able to help. 35 years + restaurant equipment repairs. Theseafox Enterprises
3/23/2024 12:56:00 AM • Kitchen Ranges • Answered on Mar 23, 2024
How old is Whirlpool Gas Range Model #10116557A
Conflicting information in the link. My best guess is 2010 Month 11.The only way to be sure is to phone them.EDIT to Add./ I just noticed you typed 'Whirpool', I have edited your post but am not able to edit my link. When it opens, add the 'L' and press Enter.https://www.google.com/search?q=How+old+is+Whirpool+Gas+Range..
3/14/2024 2:02:48 AM • Kitchen Ranges • Answered on Mar 14, 2024
Why is my commercial oven emitting so much Carbon Monoxide?
I am a retired career chef, and had this one oven with choking CO in an airport catering kitchen. We had it serviced and it was fixed. It sounds like yours is not getting enough air mixed with the gas. Adjusting the gas is one thing but the venturi to the burners can partially block and unburned gas spills over. Remove the burner and venturi and boil it out in whatever you boil your fryers out with. Are you on mains gas or propane because the jets are different. https://www.google.com/search?q=commercial+oven+emitting+too+much+Carbon+Monoxide ..
3/1/2024 12:19:25 AM • Kitchen Ranges • Answered on Mar 01, 2024
Oven temperature not what it should be. Set at 350 and my oven thermometer only went up to 335.
That seems quite common. Place your temperature sensor, alongside the therocouple of the oven, to check its accuracy.
2/23/2024 9:36:59 PM • Kitchen Ranges • Answered on Feb 23, 2024
Where can I find a maintenance manual for a Teba TFB21Y gas cooking stove
There isn't one for the reason I stated before. Call for service. https://www.google.com/search?q=Teba+TFB21Y+service+manual The only thing available is Parts, but that is for service engineers.
Teba TFB21Y (TFB21F20) oven spare parts - FixPart
fixpart.ie https://fixpart.ie > oven-spare-parts > tfb21y-tfb21f20 Teba TFB21Y (TFB21F20) oven spare parts needed? ? 16+ spare parts deliverable. ? Next day delivery* ? Customers give us a 9.0. ..
2/23/2024 4:04:39 AM • Kitchen Ranges • Answered on Feb 23, 2024
2answers
Oven won't turn on but gas and range hood are working.
Here is text followed by a YouTube. Possible reasons why your oven won't turn on even though the gas and range hood are working: Igniter: The igniter is responsible for lighting the gas in the oven. If it's faulty, the oven won't turn on. You can check if the igniter is working by looking for a glow when you turn on the oven. If there's no glow, it's likely that the igniter needs to be replaced. Wires: The wires that connect the oven to the power source may have come loose or be damaged. Check the wires for any signs of damage or looseness and replace them if necessary. Safety valve: The safety valve regulates the flow of gas to the oven. If it's faulty, the oven won't turn on. You'll need to hire a professional to repair or replace the safety valve. Top 4 Reasons Oven Won't Turn On - Gas Range Troubleshooting (youtube.com)
2/22/2024 12:56:43 PM • Kitchen Ranges • Answered on Feb 22, 2024
Broan Nutone Range Hood RL6100C, high speed fan works but low speed does not. I am wondering if a new switch is needed?
Yes it is likely to be the switch. I have one of these as well. Remove the switch and test it with a multimeter. https://www.google.com/search?q=Broan+Nutone+Range+Hood+RL6100C ..
2/16/2024 6:29:14 AM • Kitchen Ranges • Answered on Feb 16, 2024
Where can I get a thermocouple for a Teba TFB21Y gas stove
It appears they are made in Turkey and for some reason my Malware program doesn't like their webpage
Home ' Teba Heating Stoves & Pellet Stove - We've been ...
teba.com.tr https://www.teba.com.tr Teba Heating Stoves Produce Ideal Solutions For Different Places With Environmentally Friendly, High Efficiency, Comfort, Savings, Safe And Convenient Use ... Parts https://www.google.com/search?q=teba+TFB21Y+parts Thermocouples are pretty standard. https://www.google.com/search?q=teba+TFB21Y+thermocouple ..
2/16/2024 4:10:10 AM • Kitchen Ranges • Answered on Feb 16, 2024
How to replace Forno gas range oven igniter please?
Not a make we know here. It is just a matter of finding the unit, undoing the screws and wires https://www.google.com/search?q=replace+forno+gas+range+oven+igniter ..
1/28/2024 11:49:16 PM • Kitchen Ranges • Answered on Jan 28, 2024
2answers
Need self-cleaning instructions....missing manual.
To Self-Clean: 1. Close the oven door. 2. Move the door lock lever to the right to the locked position. 3. Press CLEAN. 4. Press the "up" or "down" arrow pad. CL-M (Clean - Medium soil, 3 hours) appears in the display. If the door is not closed, beeps will sound and "door" will appear in the display until the door is closed and the Clean pad is pressed again. If the door is not closed within 45 seconds, the self-cleaning operation will be canceled and the display will return to the time of day. If more than 5 seconds elapse between pressing the Clean pad and the "up" or "down" arrow pad, the program will automatically return to the previous display 5. To choose a clean setting other then Medium, press the "up" or "down" arrow pads to scroll through the self-cleaning settings. CL-H (Clean - Heavy soil, 4 hours) CL-M (Clean - Medium soil, 3 hours) CL-L (Clean - Light soil, 2 hours) Choosing a cleaning level automatically programs the selfcleaning time. 6. After 4 seconds, the oven will start cleaning. "LOCK" and "CLEAN" will appear in the display. The cleaning time will count down in the display. To Delay Start Self-Clean: Before delay starting Self-Clean, make sure the door is closed completely or it will not lock and the cycle will not begin. 1. Press DELAY. "DELAY" will flash and "00:00" will appear in the display. 2. Press the "up" or "down" arrow pads to enter the amount of time you want to delay the cycle. Delay time can be set from 10 minutes (00:10) to 11 hours and 59 minutes (11:59). 3. While "DELAY" is flashing, press the CLEAN pad. "CLEAN" will flash in the display. 4. Press the "up" or "down" arrow pad. CL-M (Clean - Medium soil, 3 hours) appears in the display. 5. To choose a clean setting other then Medium, press the "up" or "down" arrow pads to scroll through the self-cleaning settings. CL-H (Clean - Heavy soil, 4 hours) CL-M (Clean - Medium soil, 3 hours) CL-L (Clean - Light soil, 2 hours) Choosing a cleaning level automatically programs the selfcleaning time. After 4 seconds, "CLEAN," "DELAY," and "LOCK" will appear in the display to show that the oven is set for a delayed clean operation. The delay time is displayed
1/4/2024 7:59:34 AM • Kitchen Ranges • Answered on Jan 04, 2024
Gas Cooker Manual Taylors 041 marine gas cooker
Yes
1/2/2024 5:02:12 PM • Kitchen Ranges • Answered on Jan 02, 2024
What conversion lp kit is used with # mode JBP35AEAA?
no info generic do a search using make and model of your mystery appliance notify manufacturer or your paperwork for assistance on parts available
1/1/2024 2:50:27 PM • Kitchen Ranges • Answered on Jan 01, 2024
Neff Appliances Series 1 U17M42 Stainless Steel 60 cm Double Built-in Electric Fan Oven 45 l 30 l, A Energy Rating Logo
1 questions posted
Top Neff Appliances Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Neff Appliances Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Neff Appliances Kitchen Ranges
Most Popular Question
broan nutone range hood rl6100c high
  • Kitchen Ranges
