20 Most Recent
Canon Pixma IP2700 Inkjet Printer 7 ipm, 4800x1200 DPI, Colour, PC/Mac Questions & Answers
Orange light flashing 16 times in my canon printer ip2700 series
Flash sequences around 13 to 15 are usually faults with ink cartridges or cartridge recognition and often indicate a faulty print head. Flashes of 17 or more are designated as service errors and usually require turning the machine off and back on in the vain hope the problem will miraculously disappear.
First check your ink cartridges are not empty and are clean, likewise the cartridge socket is clean. If not - clean or replace as needed and test again.
If there is no obvious problem with the cartridge, you should probably consider replacing the machine.
Canon Pixma MX870 won’t turn on
my suggestion : take your printer to an authorized service center, probably the printer has a defective electronic board, there is nothing you can do to fix it
How do I reset Canon TS9020 printer to get rid of system error 5b00
Check out the videos on resetting Canon printers. They all follow a theme.Looks like I forgot to include linkshttps://support.usa.canon.com/kb/index?page=content&id=ART170494#:~:text=Reset%20your%20printer%20settings&text=icon.,setting%20you%20want%20to%20reset.https://www.youtube.com/watch?v=oQqMJxYRT3s...
490. What does error 5B00 indicate?
hi
- Restart the ink waste counter.
- First, disconnect the printer's power and USB cables.
- Press the Power button when opening the cartridge lid.
- While plugging the power cord into the wall socket, continue to hold the Power button.
- Press and hold the Power button until the printer begins to reset itself.
- Release it once all of the lights are turned on.
- Wait until the green power light goes out.
- After that, quickly press and release the Power button twice.
- The green light should continue to blink for a few seconds more before stabilizing.
- Close the cartridge door and try printing again if necessary.
Ink spills on your printer are a common cause of the 5b00 error in Windows 10. Reset the ink absorber if the ink absorber is full or the waste ink counter is full.
This quick-fix can be used to clear out several error codes that may appear when turning on the printer. Also, if you are unable to delete the printer in Windows 10, you can use our detailed guide to quickly resolve the issue.
