20 Most Recent
Irulu iulu 10.1 inch Andoid 4.0 Touchcreen Tablet PC Support MID Google 3G WiFi Network & Bulit-in 1GB DDR3 8GB Nand Flash With RJ-45 Connector for Ethernet/ ADSL Questions & Answers
How do I connect the Irulu keyboard to my tablet, besides by plugging the mini usb into the port on the side? Because my tablet doesn't recognize, that it is even plugged in.
first of all, make sure that your tablet has an On the go USB port or data port if not, it can only be used to charge. If you connect our tablet to a computer usb port, and your computer recognises it, then you have a data port.
If you plug in a usb memory stick, and your computer can not read it, it does not have a USB to go port.
Also, some Cable adapters are On the Go wired, and may not work properly.
It may also be that the USB port is not providing enough power from the tablet to the keyboard. In that case, buy a split power usb cable, and plug the red (power only) into a usb charger or powered usb hub.
How to an lock my tablet forgot passwort
Someone else asked the same question. I copied and pasted the answer to save it for myself. (This is _not_ my answer. I am quoting the technician who gave it, including her name).
Note: This ''should'' work regardless of manufacturer. It is an ''Andriod'' thing.
Andoid cell phone reset
Here are the steps to perform a hard reset in your device:
1. Switch off the device.
2. Now press and hold Volume Down + Volume Up + Power button, and release them, when you see menu of Bootloader Mode.
3. Then select option "Recovery" from the menu, using Volume Down, then press Volume Up.
4. When you see Android with triangle, then press together Volume Up + Volume Down.
5. After that select option "wipe data / factory reset" using Volume buttons to browse option, and Power button to confirm operation.
6. Choose option "Yes -- delete all user data" and accept with Power button.
7. Press Power button to select option "reboot system now".
Best Regards,
Katy
Motorola Support
Having trouble trying to figure out how to do the touch screen calibration
Touch screen is not supposed to be "calibrated" by users. All my family uses touchscreen smartphones and computers and NEVER anyone mentioned the need of calibrating a touchscreen. If you have some problem with your touchscreen, it is something beyond standard devide operation and you should take it for service, if it is on warranty, to site where it should be serviced
