20 Most Recent
Irulu 7" Touch Screen 2gb Android 2.3 Tablet Pc 256m Imapx 210 Wifi3g Bundles Case Questions & Answers
How do you reset?
The most common way to factory reset an android device is these method. 1. turn off your device 2. Press the your Volume up button and power button at the same time for a period of time 3. you will see the android image appear on the screen after that you will see some options 4. Choose the WIPE DATA/FACTORY RESET by moving your selection using the Volume buttons 5. Select it using the Power Button Then wait for it to finish the resetting process.
?What do I do if I forget my password
If you can't remember any of your passwords, then as a last resort you can reset your tablet with the reset button (little pin hole in case, usually marked reset, use paper clip or hole end of sewing needle) to restore factory default setting. If you can save your data first. You could also Google a solution or find one on Android Forums. Hope this helps
How do i reset my irulu tablet if there is no
Turn it on, hold power button down until it shuts off by holding button down. "After it is shut off", most tablets ... you are able to press the power and volume keys at the same time (volume key up or down) to reboot into the recovery mode. Enjoy this useful information that none of the tech's like to share, well ... besides me. ")
