20 Most Recent
Irulu 7" 4gb Google Android 2.3 Touchscreen Tablet Wifi 8gb Micro Sd Card Case Bundle Questions & Answers
Why is my irulu x7 tablet so slow?
Try some highly rated free Android cleanup tools from Play Store.
I have a couple I use on my cell phone that work great. Android tablets are very similar to computers and can get clogged up with temp files and also corrupted clutter. CM security, Clean master, one tap boost.. These work nicely.. Or try Avast - I use it on my computers and phone.. It has coverage on about everything for protection.
Hope this helps to FixYa issue. Have a great night. If you need further help, I’m available over the phone at
https://www.6ya.com/expert/william_02fc2766c1e13b73
Why doesn't it stay charged?
Have you tested the battery? Probably not holding charge cause its done, old, defective!? How old is your unit and have you ask about replacements for it?? Just my suggestion. THen check out the ease of installing a new one!! Way cool!!! Good luck my friends
How do I get my apps to work?
forums.androidcentral.com/other-tablets/236406-
irulu-tablet.html
Dec 18, 2012 - 25 posts - 22 authors
I just got my irulu 4.2 Jellybean tablet and this is my first time dealing with ... I know you can't install/use an Android app on a pc but all I want to do is load it onto .... As soon as the irulu tries to open the dl'ed file, it will bring up the ... I just bought my daughter a irulu 7 in tablet and it is driving me crazy she is ...
BATTERY LOSES POWER TOO QUICKLY WHAT TO DO
I never encountered this problem, but if you turn off WiFi when not in use the battery lasts longer. Also go to settings, battery, and check what is using the most power.
How do I reset passcode
You can do a hard reset of it and put it back to factory setup like the day you got it.. Usually its pressing the Power button and the Volume Up key at the same time when booting will allow you into the settings.. You can search youtube and there are allot of tutorials that will show you step by step what to do..
How to stop talkback settings?
To scroll through the menus with talkback on, double tap and scroll with two fingers.
This should let you do the settings > option > accessibility >........
Follow to find deactivating "for blind".
Good luck.
Can't insect my sim card, can u help
I'm assuming you mean "insert" rather some crawly creature. SD cards are designed to only fully seat in one way. I'd suggest turning the card over and trying again. Take a flashlight and look in the slot to be sure something isn't blocking (remember VCR's,lol). It should slide in with little pressure, the last 1/4" might feel tighter but that's a spring compressing to take it out. Finally have you tried the card in another machine?
Good luck
