20 Most Recent
JVC AV-27320 27" TV Questions & Answers
My jvc tv is stuck
hi,
Do one thing remove the power socket wait for 3 minutes and then reconnect the power code. then switch the tv the timer will reset.
ok
The sound on my tv is off and i dont know how to
some tv's have a button on the back that will turn on or off the built in speaker system so that the tv can be plugged into an external system and allow the user to use the tv's volume control for the ext. speakers without hearing the internal ones, if there is no such button check the tv's setup menu for a setting that enables or disables the speakers
How to find JVC AV27320 headphone jack? I've
This model doesn't have a headphone jack. The only JVC TV in the series that does is the model AV-20D202. For the JVC AV-2732, use the RCA audio out jacks with an RCA to 3.5 mm adapter to connect to the headphones. The front audio jacks are audio in (for the audio from a video camera for example).
When you use any external speakers or headphones through the audio out jacks, make sure to turn off the TV speakers. Press Menu and navigate down to TV Speakers (up/down arrows). Then use the right/left arrows to select Off and then Exit the menu. Make sure you scroll the TV volume before doing this. Note: if your headphones do not have a volume control they are a bad choice for this type of audio output.
You can find the manual for the TV here:
http://books.jvc.com/booklist.asp?Model=AV-27230 .
I wish that I had better news for you.
Dark screen
the sound is locked off the TV good picture
JVC tv "stuck" on sleep timer
I think you would have to turn off the sleep timer mode completely or increase its ON time span, say to 4 hours or so
or the lenth of time you have the TV on for. If that does not fix it then it sounds like a STANDBY MODE fault problem.
Hope this helps.
Cannot readjust
sounds like a clasic tube failing sooner or later it will be so dark u wont be able to adjust it or it will just loose the pic all together sorry for the bad news:)
Tv problem
cant remember how to reset the lock key but its in the manual and if u lost it u can get it online at jvc.com.....good luck
JVC Vertical Problem
You need to adjust the vertical height in the Service menu.Press the SLEEP TIMER key and set the SLEEP TIMER for
「0 MIN」.
Then press the DISPLAY key and VIDEO STATUS key of
the remote control unit at the same time to enter the Service menu.In SERVICE MENU, press the FUNCTION ▼/▲ key to
select any of the SUB MENU items.
(The letters of the selected items are displayed in yellow.)You want #2 DEF - go to sub-menu and look for the height adj.
FUNCTION / key
Setting (adjust) the SETTING VALUE of the SETTING ITEM.
When the key is released the SETTING VALUE will be stored
(memorized).
EXIT key
Returns to the previous screen.
