20 Most Recent
Ibanez S5470 Prestige Electric Guitar Questions & Answers
Wiring a guitar
Here's the diagram.You should have all 4 wires from the humbucker pickups if you want the 2nd and 4th position to work.
Had my guitar PLEK'd because
Take it in for setup. Likely the truss rod or the bridge is out of adjustment. Wrong strings can also cause the problem. There are YouTube videos on guitar setup... I would NOT attempt truss rod adjustment yourself.
My s5470 ibanez has a
Volume levels change depending on the settings... Also the harmonic content changes so the "apparent" volume will seem different. Find somebody else with the same unit and compare them side by side. Also the type of strings MAY change the sound.
My s5470 does not sustain
I personally use Seymour Duncan Humbucker pickups, and have never been disappointed. You might want to take your guitar up to a music shop and try it on different amps to see if your amp is your problem, or if it is your guitar's pickups or wiring. You could also try adjusting the height of the pickups until the sound you are looking for is achieved. I have also had guitar cables make a big difference in the sound. Make sure you have a good set of cables, and you may want to adjust the EQ settings of your amp to make up what the guitar lacks. I’m happy to help further over the phone at
https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
What type of input Jack do I need for a ibanez guitar amp tbx30r?
i believe you need a 1/4" unbalance plug for the amps input. Basically a guitar cord. If I am understanding the question. ? or if you want to know the actual "input jack",Maybe it is lacking or missing? than that would be a "1/4" unbalanced input jack". good luck, I hope this helps.
8/26/2019 10:28:56 AM •
Ibanez Music
Answered
on Aug 26, 2019
