20 Most Recent
Ibanez P500H Promethean Bass Amplifier Head (500 Watts) Questions & Answers
When i play a bit
does your bass have active pick ups?
do the ratings on your amp match the ratings on your speaker?
are you using a pedal?
does your pedal have an output adjustment?
have the ground on your bass checked.
make sure you're using the right kind of cable.
and be sure that the outlet you're using is grounded.
Wiring a crate 2 button
Mixing brands on footswitches, even within the same brand but different series is NEVER a good idea. While many can be converted by elecvtronics competent techs, the effort is usually not worth it for anything other than the simplest footswitch.
Line out seems to not
This uses a balanced line output requiring the receiving device have a balanced input OR you would have to use a DI or BALUN to convert to unbalanced for devices without a balanced input.
If the receiving device has an XLR input then it will be ballanced and using an XLR to XLR cable should work.
You did not mention what you were trying to drive so I can't help much more than what I have said.
What type of input Jack do I need for a ibanez guitar amp tbx30r?
i believe you need a 1/4" unbalance plug for the amps input. Basically a guitar cord. If I am understanding the question. ? or if you want to know the actual "input jack",Maybe it is lacking or missing? than that would be a "1/4" unbalanced input jack". good luck, I hope this helps.
8/26/2019 10:28:56 AM •
Ibanez Music
Answered
on Aug 26, 2019
