20 Most Recent
Ibanez Ael20e AcousticElectric Guitar with Onboard Tuner Questions & Answers
I have found that Ibanez
There is little data on the internet about this... However my AEL20E uses 2 AA cells. Some older ones may have used a 9 volt battery. Yours should use the 2 AA cells which go into the box right by the XLR output plug.
Just purchased a used Alvarez FF60WR. The
my on board tuner used to do that. I just tried to tune the guitar normally and it usually worked after a couple of seconds. The tuner needs sound to work - it won't work without you playing any notes :)
Dear Team,
My Ibanez AEL200 has B-Band preamp and
Hi,A very simple, easy and useful out - black BIC razors http://i00.i.aliimg.com/photo/v0/117854392/BIC.jpgGet BIC round-black razors, cut around 1,5 cm long tops, shape them out, use rubber-glue internally, dry and then place them onto the pots... that's the best solution and costs nothing. Good luck!
Hi, My Ibanez AEL 20
Remember that while in tuner mode, the audio output is disabled. Try additional presses of the tuner button to see if the audio comes back on. Also verify the volume and EQ gains are turned up. Verify the battery is new.
My acoustic electric guitar is giving intermittent
A common problem is a WORN jack that is caused by the user NOT looping the guitar cable through the strap or their belt loop. The rotation of the cable as it is played wears both the plug and the jack and causes noise and dropouts. Also verify that the battery connections are corrosion free. Also verify the problem is not with your amp.
My ibanez Ael20 works for
Make sure you are using a TS type cable (standard guitar cable, not balanced). Make sure the tuner is off as there are modes for tuning that kill the outgoing audio during tuning.
What type of input Jack do I need for a ibanez guitar amp tbx30r?
i believe you need a 1/4" unbalance plug for the amps input. Basically a guitar cord. If I am understanding the question. ? or if you want to know the actual "input jack",Maybe it is lacking or missing? than that would be a "1/4" unbalanced input jack". good luck, I hope this helps.
8/26/2019 10:28:56 AM •
Ibanez Music
Answered
on Aug 26, 2019
