20 Most Recent
Minolta Maxxum 300si 35mm SLR Camera Questions & Answers
I have tried AA batteries and the cover
The Maxum 300si uses one six-volt 2CR5 battery, which should be available at just about any electronics store. Try a Radio Shack, if they exist in your corner of the world.You may download a copy of the manual
from here.
Programme Screen flashing in error
Sometimes cameras get "confused" if the battery is allowed to die and is replaced. Remove the batteries and wait 30 minutes for the camera to reset then put the batteries back in. This works on rare occasions and does not cost anything to try.Hope that helps,Bax
Minolta Dynax 500si
Part 1:
http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/dynax_maxxum_400si/Maxxum400siManual-Part1.pdf
Part 2:
http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/dynax_maxxum_400si/Maxxum400siManual-Part2.pdf
I love my Minolta camera. I want to get a
if you want to use your current lens, then your only new choice is any of the Sony Alpha dSLR's as they use the Minolta AF mount.
However... your lens will not operate correctly. You may have to manually focus and the auto iris stop down might not work. The only way to find out in advance to to take your lens along to a Sony stockist to try it out, but phone them in advance to ensure that they have a display model with a freshly charged battery.
You will definitely find that your 35mm film lens will have a different angle of view; the smaller sensor on the dSLR means that your lens will appear to have a 1.5x teleconverter fitted. You'll also likely find that your lens will be optically inferior to the modern offerings simply due to greater advances in computer aided design and materials technology, although the actual build quality of your lens may well be better.
On balance, I'd suggest that you continue to use your Minolta 35mm camera and if you buy a digital SLR system just make a clean break and pick whichever system suits your needs best. Unless you already own late model 35mm AF Nikon or Canon gear there's really very little to be gained by trying to use your old equipment on the new dSLR body and potentially a lot of handling issues to interfere with taking photos.
