20 Most Recent
Minolta Maxxum 400si 35mm SLR Camera Questions & Answers
I have purchased a maxxum 450si
You have a film camera, you should have AF lenses. The AF lenses are larger round then older manual lense as you can have the older Minolta lens will fit the newer cameras, just not auto focus. If your AF is not working with AF lenses, I will assume you have power to the camera (batteries) These camera are not hard to use. To AF the camera, press the shutter down slightly (you can try without film) and it should focus on the center of your shot. Indoor and under low light, they will have trouble with these older AF bodies.
Slow snapping picture
I am not sure, but have you played with the camera manual setting ?
if you did
you should change the shutter speed to a higher level (if you have used the manual mode)
but if you use the automatic mode and the light around you was low the shutter speed will be automatically low so the camera could give you a better picture be lowering the shutter speed so it could have the enough time to collect the light (that's why the snapping is slow)
so try to increase the iso or the av (lowering the av's number)
hopefully, I have helped you
My tilt/shift lens isn't working with my Minolta
Is this an auto focus lens? Most shift lenses are manual focus. Also, because they shift, they can generally only be used on manual not he auto settings. If the contacts are not on the back of the lens then it will on communicate with the body
How to put camera in automatic focus
The af/manual switch is located on the side of the mirror box. However, this model was notorious for failure of the auto focus motor. Also check the lens to make sure the focus moves smoothly (take off camera)
Can't find any batteries
Any strange shaped specific battery has multiple commercial batteries inside that are spot welded to each other. The interior can be replaced with new rechargeable commercial batteries if necessary.
I can't get my camera out of auto focus
Did you push down the lever on the side of mirror box to switch it to manual focus? If so and it is still not going into manual focus, then the switch may be damaged (bent switch contacts etc.). You can check the switch by removing the bottom and front covers. Beware of loose parts!
I want to put a new lens on called "wide angle
Well, I'm sure you figured it out by now, but typically there is a small red dot on the lens, near the connecting ring... This lines up with a similar dot on the camera. There is only one way the lens will go on, and still have auto-focus and other functions be able to be controlled by the camera.Sometimes, when someone is handling a lens, it is possible to move the lock ring. This will keep the lens from engaging at all, with the camera. Try that area. Doc
