20 Most Recent Minolta Maxxum 7000 35mm SLR Camera Questions & Answers
Is the camera turned on; okay simple question but sometimes that is all that is needed. Look in the battery compartment is it clean, does it have battery corrosion? Sometimes the wires in the battery compartment become corroded thus not making a connection. If so a CLA will be needed.
Minolta Maxxum... | Answered on Nov 28, 2016
This camera is powered by a 6-volt 2CR5 battery. Check the battery, look at the camera battery condition indicator. If it is all black the battery is fully charged. If it does not show all black or partially black remove the battery and test it with a battery tester. If the battery checks good then look inside the battery compartment making sure it is clean without any battery leakage. Again, if the battery and battery compartment are clean as they should be then it may need a CLA.
What about the first frame? We need more information!
Minolta Maxxum... | Answered on Jan 06, 2015
7000s were made from late 70s to mid 80s
Minolta Maxxum... | Answered on Jan 04, 2015
Shutter prob jammed and needs to be re-lubed, Common problem with this mode. Comes from lack of use.l
Minolta Maxxum... | Answered on Oct 26, 2014
Try fresh batteries. Check for corrosion from leaking batteries on contacts and where battery compartment snaps onto battery door. Clean corrosion if there. If you do not measure over 6 volts at the two metal contacts on the door, then this is probably the problem (very common). Otherwise, failure of motor, loose screw in transport gearing unit on top
Minolta Maxxum... | Answered on May 14, 2014
Any camera store will carry 35mm film, color or black&white, transparency or negative. A narrower selection will also be available at many department or drug store, as well as some supermarkets.
Minolta Maxxum... | Answered on May 10, 2014
Batteries good? Contacts clean? If battery leakage clean and retest. Is the camera autofocusing? Did this start after you loaded film? Did the camera advance to 1?
Minolta Maxxum... | Answered on Jan 21, 2014
Minolta Camera Repair (Konica) ' Authorized Service Center ...
www.precisioncamera.com/minolta-camera-repair.html - United States
Minolta Maxxum... | Answered on Mar 31, 2013
You posted this question in the "Film Cameras" area of FixYa. Please repost in an appropriate area so that the proper experts may see it and give you an answer.
Minolta Maxxum... | Answered on Sep 17, 2012
Minolta Maxxum 7000 35mm SLR Camera Logo
152 questions posted
Top Minolta Photography Experts
Ekse
Parshiv Luthra
Are you a Minolta Photography Expert? Answer questions, earn points and help others
View Most Popular
Minolta Photography
  • Minolta Photography
Most Popular Question
need kno off button minolta maxxum 7000
  • Photography
