20 Most Recent Olympus DS-4000 Digital Voice Recorder Questions & Answers
ERR symbol on VN-2100PC
I'm afraid that the only solution I can think of would be to put in a new set of batteries. If your quick about it, your might not lose the information.
3/16/2018 11:26:03 PM • Olympus DS-4000... • Answered on Mar 16, 2018
4answers
Olympus DS4000 says Memory Error
I had several cases lke this with clients. One of the dictations is corrupted. It's the "one" here that matters. When you connect the DS-4000 to a PC, it appears in your "My Computer" as a Removable Drive. Browse this drive, and you will find the dictations in one of the folders (A, B, C etc...) or they might be scattered between folder depending on how your user records.
Try to copy dictation manually from that drive to the matching folders on the PC (by default My Documents-->DSSPlayer-->Messages-->FolderA, FolderB..., although you might have changed that).
At some stage one of the dictation files will refuse to copy/paste: that's the corrupted one; however should should be able to save the others. Once you have salvaged all but one dictation, you can do a format of the card. In fact, I suggest you chage the card, as corruption is usually a sign of worst things to come...
Using this procedure, at least only one dictation will need re-dictated.
I hope this helps.
5/17/2017 1:18:05 PM • Olympus DS-4000... • Answered on May 17, 2017
How can i get the NEW button repaired on ds olympus dig.recorder?
If you press the new button and it doesn't start a new file it is possible that the little microswitch is broken from the circuit board. I have repaired about 10 of these on ds-4000's If you have patience and can use a soldering iron it is possible for you to repair it yourself. You have to take the back cover off first and then the front cover. Then you can take the function knob off. All of these come off with removing little screws,from each assembly. This will get you to the switch and you can look at it to see if it is broken from the circuit board. If it is broken from the board(usually 1 leg of the switch ) you can resolder it to the circuit path. All you need is a small needle point soldering iron and some thin solder. You may find these at a Radio Shack near you. Or You can also sedt it to Smoltz business products they repair these models. I do not know what they charge but they are very good at repairing these units
4/14/2015 1:05:19 AM • Olympus DS-4000... • Answered on Apr 14, 2015
Dictation module stopped opening
Have you found your answer yet? In my case, it was the upgrade to latest version ie. Was using 9. ie 11 stole bits of code.
1/22/2015 4:23:14 PM • Olympus DS-4000... • Answered on Jan 22, 2015
DSS player won't download to PC
I know you will need the serial # to install, if you don't have one you can get this software version it say that it is for the Olympus DS-5000 digital recorder but also it is compatible with the previous version Olympus DS-4000 digital recorder at http://www.tvps.com/Products/Olympus-AS-5001-DSS-Player-Pro-Dictation-Version-5---New__OL-AS-5001.aspx
5/8/2014 1:46:42 AM • Olympus DS-4000... • Answered on May 08, 2014
0answers
How do I get Olympus DS-4000 to work on Win 8 64-bit
do you have programs files (86) in your PC "C" drive menu menu? If yes that;s where yiou should install the software. That's because it;'s a 32 bit on a 64 bit.
11/12/2013 8:54:39 PM • Olympus DS-4000... • Answered on Nov 12, 2013
2answers
How to remove the write
The DS4000 has a lock option available from the menu. press the menu and scroll untill you find lock. If you did not prposely lock the file, most likely the files on the memory card are corrupt. You will need to reformat the memory. The format option is in the menu as well.
5/1/2013 7:22:24 AM • Olympus DS-4000... • Answered on May 01, 2013
Memory card is locked philips lfh 9600
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
1/8/2013 7:54:47 PM • Olympus DS-4000... • Answered on Jan 08, 2013
Lost installation disk for olypmus 4000 dictation module
You may download the software from here.
10/6/2012 7:43:31 PM • Olympus DS-4000... • Answered on Oct 06, 2012
2answers
What is the best digital recorder for a lawyer --
The Phillips LFH-9600 is a popular unit in the professional category.
Everyone will have their preferences....also check on Warranty and service for your geographical area, as these are issues to consider before purchase.
4/25/2012 6:33:31 PM • Olympus DS-4000... • Answered on Apr 25, 2012
Does the RS25 foot pedal work with windows 7?
You must have the RS27 foot control to work with Windows 7
1/13/2012 4:15:00 AM • Olympus DS-4000... • Answered on Jan 13, 2012
How do i unlock the
The lock function can be found in the menu, however if you did not go there to lock the files, chances are your memory is corrupted. You can reformat the memory from the menu but this will wipe out any recordings. If you need to recover the files, try PC Inspector, Smart recovery. This is a free download, just search google.
8/11/2011 3:48:47 PM • Olympus DS-4000... • Answered on Aug 11, 2011
I own an Olympus DS-4000
Olympus uses a Device detector utility to detect the recorder. Some other applications can keep the recorder from being detected. Check for Adobe Download manager running in the tray. If it is, disable and it may work. Some printer controle managers also can cause this not to work.
Also, check if the recorder is listed as a removable drive under My Computer.
7/14/2011 8:01:41 PM • Olympus DS-4000... • Answered on Jul 14, 2011
Olympus DS-4000 Digital Voice Recorder Logo
97 questions posted
Top Olympus Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Ngoro
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Olympus Audio Players & Recorders
Most Popular Question
memory card locked philips lfh 9600
  • Audio Players & Recorders
