20 Most Recent
Olympus WS-200S Questions & Answers
Files deleted from Olympus WS-200S - Can i get them back???
Unfortunately this recorder model is designed with flash memory and once the files are erased they are gone. There are some companies that do specialize in flash memory recovery (Olympus is not one of them). You can go to google and search for flash memory recovery specialists. However this is a very costly process as it involves sending the device to these companies for them to do the recovery process.
Erasing
I had the same problem. I downloaded the instruction pamphlet at
http://www.olympus.co.jp/en/support/imsg/vtrek/download/manual/ws/man_ws100_ws200s.pdf
and reformatted the recorder. It seems to work fine now.
Formatting the Recorder (FORMAT)
If you format the recorder, all function settings will return to their defaults.
All files stored in the recorder will be deleted.
If you have important files that you want to save, connect the recorder to a computer and
transfer those files from the recorder to the computer before formatting the device.
1 Press the MENU button.
2 Press the FF or REW button to choose “FORMAT”.
3 When the PLAY button is pressed, “nO” is displayed.
4 Press FF or REW to select “yES”, and press the
PLAY button.
After “ARE yOU SURE” is displayed, “nO” will be displayed.
5 Press FF or REW to select “yES”, and press the
PLAY button.
“DONE” displays when formatting ends.
s It may take up to several tens of seconds to finish the initialization. Do not remove the battery or detach
the battery compartment from the recorder during that time. Otherwise data may be damaged.
s Never format the recorder from a PC.
s When the recorder is formatted, all the stored data, including locked files, are erased.
Ws 200s deleted files but still full
I had the same problem. I downloaded the instruction pamphlet at http://www.olympus.co.jp/en/support/imsg/vtrek/download/manual/ws/man_ws100_ws200s.pdf and reformatted the recorder. It seems to work fine now.
PLAY button.
PLAY button.
My Olympus WS-802 recorder has a "down volume" issue, where it just won't work, I can't lower the volume
It sounds like the water damage may have caused the down volume button to malfunction. While it may be possible to fix the button, it would require opening up the device and performing some troubleshooting, which can be difficult if you don't have experience with electronics. I would recommend taking the recorder to a professional repair shop or contacting Olympus customer support to see if they can assist you with repairs. If the device is still under warranty, they may even be able to provide a replacement.
