20 Most Recent
Mitsubishi ColorView XL30U Multimedia Projector Questions & Answers
Xl30u
I would be its the polarizers. Whats it doing?
Input is out
sometimes the output is in, but the signal is not there.
try the other inputs with other signal sources and see if all are not working
Input not working
Xl30u has a very green tint to the image.
the light filter on one of the lecd panels is fried due to excessive dust and heat. unfortunately, you'll have to replace the entire optical engine, as the manufacturer does not sell individual parts.
Mitsubishi hc1500 banding
If you're using the VGA port, you'll see the banding because it's not really showing 720p, it's doing scaling (I'm not sure from what resolutions it's scaling). So, even though you're using VGA at 1280x720, the scaling is still going on and it's showing the banding.
You have to use HDMI to get true 720p.
Yellow area in the projected image
Hello Media Man,
Looks like your projector has done it. Thats acommon trouble to ageing polirising lens, usually the blue. less blue, the green and red make up the yellowish image on the screen. The blue is bombarded with tremendous heat from the lamp and it fade and wash out. If its free, its worth replacing. Get quote for the poliriser; 2 pieces each color.
Good Luck.
RESET LAMP HOURS
Hi Greg147
The resetting is not done in the menu.
Plug in your power cable - Machine is now in standby mode.
Then Hold down the left and right arrow keys on the Projector and press the power button. You'll see a indicator light on top of the Projector flashing twice - Lamp hours is now reset.
Hope this is of help.
HC3800 Mitsubishi color wheel model or part number?
The Mitsubishi HC3800 projector uses a color wheel with the model number VLT-HC3800LP. This is the original color wheel that is designed specifically for the HC3800 projector, and it should be able to replace the existing color wheel in your projector. It is important to use the correct color wheel for your projector to ensure optimal performance and avoid any damage to the projector.
You can purchase the VLT-HC3800LP color wheel from Mitsubishi authorized resellers or from the Mitsubishi website. You can also check for other electronic resellers or online marketplaces for availability and pricing. I recommend you to confirm with the seller that the part is compatible with your specific projector model and serial number, before making the purchase.
It's also important to mention that, replacing the color wheel should solve the noise issue you're experiencing. But, it's always recommended to check the projector warranty status, or if the projector is out of warranty, consult with a professional technician before attempting to replace any part of the projector.
