20 Most Recent
Mitsubishi SL4SU ColorView Multimedia Projector Questions & Answers
Zoom focus
It has a magnify feature on the remote I think. You can reset the machine by holding down power computer and video buttons for a long time.
Blinking Light on Mitsubishi SL4SU Projector
To jmatthews
Both power light and status light a solid red with no response to any buttons indicates the bulb timer has expired. You need to reset the timer by pressing and holding the left arrow key, the right arrow key and the power button all at the same time for a few seconds.
If there are no problems, the projector will fire up, but you must replace the bulb as it will fail soon and perhaps explode when it does.
Take care
Yellow spot
the problem is in the light path starting with the blue input polarizer then the blue lcd hopefully its just the input polarizer. worst case you will have to replace the LCD block witch is expensive to do. the polarizer ia a speacialy tinted glass designed to help with the LCD's temp.
Mitsubshi sl4su
THis is a very short throw even for a "short throw" lens. I would verify that this is the proper lens by its numbers and verify what you should be seeing by its tech specs (focal distance./image size to be expected)
Mitsubishi SL4SU
what is the status and power doing because there is no information here
How to reset the bulb life to 0 on a sl4su it
hi,
Do the following for reset the lamp hour to zero.
Reset the timer by pressing and holding the left arrow key, the
right arrow key and the power button all at the same time for 5
seconds.
OK
My SL4SU projector will not
ok make sure its nt to close or far away and the focus ring should be in the midle to find out how to get a good focus hook up a laptop and search google for projector focus chart and use that and blam should be focused
HOW DO I CHECK LAMP LIFE FOR MITSUBISHI SL4SU
If you go into the menu of the projector.
Find the lamp status or info command.
It will tell you the current information.
Please dont forget to vote this answer was helpful and accept my answer.
Many thanks
Sl4u Projector
It could be that one of the fans has broken you will be able to hear them because there are 5 in there. if you are under warantee send it back if you are technically minded take it apart and watch which fan doesnt start then order from mits or from a local supplier,.
HC3800 Mitsubishi color wheel model or part number?
The Mitsubishi HC3800 projector uses a color wheel with the model number VLT-HC3800LP. This is the original color wheel that is designed specifically for the HC3800 projector, and it should be able to replace the existing color wheel in your projector. It is important to use the correct color wheel for your projector to ensure optimal performance and avoid any damage to the projector.
You can purchase the VLT-HC3800LP color wheel from Mitsubishi authorized resellers or from the Mitsubishi website. You can also check for other electronic resellers or online marketplaces for availability and pricing. I recommend you to confirm with the seller that the part is compatible with your specific projector model and serial number, before making the purchase.
It's also important to mention that, replacing the color wheel should solve the noise issue you're experiencing. But, it's always recommended to check the projector warranty status, or if the projector is out of warranty, consult with a professional technician before attempting to replace any part of the projector.
