20 Most Recent Premier Range. 36 in. Freestanding Sealed Burner Gas Range in Stainless Steel P36S348BP Questions & Answers
0answers
OVEN
Be the first to answer 4/16/2015 4:35:16 PM • Premier Range.... • Posted on Apr 16, 2015Be the first to answer
How do I adjust the oven thernostat on a Premier Pro series gas range, it is only heats to 350 when set to 550
  1. Turn off the oven and unplug it from the electrical outlet.
  2. Locate the thermostat dial inside the oven.
  3. Using a small screwdriver, turn the thermostat dial to the desired temperature setting (e.g. 550°F).
  4. Plug in the oven and turn it on.
  5. Allow the oven to preheat to the set temperature for 15-20 minutes.
  6. Place an oven thermometer in the center of the oven to verify the actual temperature.
  7. If the oven temperature is still not correct, repeat steps 2-6, adjusting the thermostat dial as necessary.
It's important to note that some models may require a professional to calibrate the oven thermostat,
2/1/2023 6:12:15 PM • Premier Kitchen... • Answered on Feb 01, 2023
Premier stove model SMK240T. oven electronic ignition is not working. top burners light fine
There is a spark ignition plug near the burner. It could be dirty or the lead has come off. If you can hear the sound of the spark, that would mean that power is getting to the plug. If the problem continues you might consider buying a hand held gas igniter. Far cheaper than a service call.
11/20/2018 7:38:30 AM • Premier Kitchen... • Answered on Nov 20, 2018
0answers
How can I remove oven door for cleaning
There is a VERY complete tutorial on how to remove your oven door for hinge replacement or just for cleaning at https://www.youtube.com/watch?v=6YFTYWsiO1M The narrator is clear spoken and the instructions are easy to follow not to mention the fact that you can go back to it any time for a refresher if you need to. Most ovens are very similar in how the doors work so this should do the trick. then watch the next one for the cleaning directions https://www.youtube.com/watch?v=GP2OC-NwxYU I would add that you might want to wear rubber gloves. As a 5' woman I found that the oven door was a little heavy and the extra grip is handy. Be sure to have something ( like a small coffee table) to set the door on as soon as it's loose to prevent back strain.
3/23/2015 10:41:17 PM • Premier Kitchen... • Answered on Mar 23, 2015
Premier free-standing gas range, 20", how much clearance from wall?
If you are seeing the bubbled paint on wall when you open the oven door, it is more than likely heat loss past the door gaskets. They are easy to install clip on gaskets
2/5/2013 9:58:02 PM • Premier Kitchen... • Answered on Feb 05, 2013
The gas oven with electrical
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
9/30/2010 11:56:57 PM • Premier Kitchen... • Answered on Sep 30, 2010
Oven too hot and uneven heat
We had the same trouble with our electric range a few years ago. We had the thermostat replaced and it has worked great ever since. Douglas
7/10/2010 9:16:57 PM • Premier Kitchen... • Answered on Jul 10, 2010
Whirlpool Range Model WBP 34500. I need a wiring diagram for it please?
Unfortunately not for that model. I realize this is an old question but it is stuck and needs answering to get rid of it. :>D https://www.google.com/search?q=Whirlpool+Range+WBP+34500+wiring+diagram ..
4/9/2024 5:46:28 AM • Kitchen Ranges • Answered on Apr 09, 2024
Sirius SU1 Wall Mount Chimney Range Hood, 600 CFM. Not working at all. Replaced board?
It sounds like your new board is faulty or there are bad connections to and from it. Have you asked Sirius Helpdesk Support? https://www.google.com/search?q=Sirius+SU1+no+power ..
3/25/2024 11:28:36 PM • Kitchen Ranges • Answered on Mar 25, 2024
I am looking for a thermostat for my Samet gas stove. Having difficulty to find the part. Any replacements that might also work?
send me a picture of the thermostat body and i may be able to help. 35 years + restaurant equipment repairs. Theseafox Enterprises
3/23/2024 12:56:00 AM • Kitchen Ranges • Answered on Mar 23, 2024
How old is Whirlpool Gas Range Model #10116557A
Conflicting information in the link. My best guess is 2010 Month 11.The only way to be sure is to phone them.EDIT to Add./ I just noticed you typed 'Whirpool', I have edited your post but am not able to edit my link. When it opens, add the 'L' and press Enter.https://www.google.com/search?q=How+old+is+Whirpool+Gas+Range..
3/14/2024 2:02:48 AM • Kitchen Ranges • Answered on Mar 14, 2024
Why is my commercial oven emitting so much Carbon Monoxide?
I am a retired career chef, and had this one oven with choking CO in an airport catering kitchen. We had it serviced and it was fixed. It sounds like yours is not getting enough air mixed with the gas. Adjusting the gas is one thing but the venturi to the burners can partially block and unburned gas spills over. Remove the burner and venturi and boil it out in whatever you boil your fryers out with. Are you on mains gas or propane because the jets are different. https://www.google.com/search?q=commercial+oven+emitting+too+much+Carbon+Monoxide ..
3/1/2024 12:19:25 AM • Kitchen Ranges • Answered on Mar 01, 2024
Oven temperature not what it should be. Set at 350 and my oven thermometer only went up to 335.
That seems quite common. Place your temperature sensor, alongside the therocouple of the oven, to check its accuracy.
2/23/2024 9:36:59 PM • Kitchen Ranges • Answered on Feb 23, 2024
Where can I find a maintenance manual for a Teba TFB21Y gas cooking stove
There isn't one for the reason I stated before. Call for service. https://www.google.com/search?q=Teba+TFB21Y+service+manual The only thing available is Parts, but that is for service engineers.
Teba TFB21Y (TFB21F20) oven spare parts - FixPart
fixpart.ie https://fixpart.ie > oven-spare-parts > tfb21y-tfb21f20 Teba TFB21Y (TFB21F20) oven spare parts needed? ? 16+ spare parts deliverable. ? Next day delivery* ? Customers give us a 9.0. ..
2/23/2024 4:04:39 AM • Kitchen Ranges • Answered on Feb 23, 2024
2answers
Oven won't turn on but gas and range hood are working.
Here is text followed by a YouTube. Possible reasons why your oven won't turn on even though the gas and range hood are working: Igniter: The igniter is responsible for lighting the gas in the oven. If it's faulty, the oven won't turn on. You can check if the igniter is working by looking for a glow when you turn on the oven. If there's no glow, it's likely that the igniter needs to be replaced. Wires: The wires that connect the oven to the power source may have come loose or be damaged. Check the wires for any signs of damage or looseness and replace them if necessary. Safety valve: The safety valve regulates the flow of gas to the oven. If it's faulty, the oven won't turn on. You'll need to hire a professional to repair or replace the safety valve. Top 4 Reasons Oven Won't Turn On - Gas Range Troubleshooting (youtube.com)
2/22/2024 12:56:43 PM • Kitchen Ranges • Answered on Feb 22, 2024
Premier Range. 36 in. Freestanding Sealed Burner Gas Range in Stainless Steel P36S348BP Logo
1 questions posted
Top Premier Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Premier Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Premier Kitchen Ranges
Most Popular Question
same vulcan stove pilot
  • Kitchen Ranges
