20 Most Recent
Premier ProSeries 24 Model P24S340BP, ProSeries Questions & Answers
How do I adjust the oven thernostat on a Premier Pro series gas range, it is only heats to 350 when set to 550
- Turn off the oven and unplug it from the electrical outlet.
- Locate the thermostat dial inside the oven.
- Using a small screwdriver, turn the thermostat dial to the desired temperature setting (e.g. 550°F).
- Plug in the oven and turn it on.
- Allow the oven to preheat to the set temperature for 15-20 minutes.
- Place an oven thermometer in the center of the oven to verify the actual temperature.
- If the oven temperature is still not correct, repeat steps 2-6, adjusting the thermostat dial as necessary.
It's important to note that some models may require a professional to calibrate the oven thermostat,
How can I remove oven door for cleaning
There is a VERY complete tutorial on how to remove your oven door for hinge replacement or just for cleaning at
https://www.youtube.com/watch?v=6YFTYWsiO1M
The narrator is clear spoken and the instructions are easy to follow not to mention the fact that you can go back to it any time for a refresher if you need to. Most ovens are very similar in how the doors work so this should do the trick.
then watch the next one for the cleaning directions
https://www.youtube.com/watch?v=GP2OC-NwxYU
I would add that you might want to wear rubber gloves. As a 5' woman I found that the oven door was a little heavy and the extra grip is handy. Be sure to have something ( like a small coffee table) to set the door on as soon as it's loose to prevent back strain.
Oven too hot and uneven heat
We had the same trouble with our electric range a few years ago. We had the thermostat replaced and it has worked great ever since. Douglas
Oven won't turn on but gas and range hood are working.
Here is text followed by a YouTube. Possible reasons why your oven won't turn on even though the gas and range hood are working:
Igniter: The igniter is responsible for lighting the gas in the oven. If it's faulty, the oven won't turn on. You can check if the igniter is working by looking for a glow when you turn on the oven. If there's no glow, it's likely that the igniter needs to be replaced.
Wires: The wires that connect the oven to the power source may have come loose or be damaged. Check the wires for any signs of damage or looseness and replace them if necessary.
Safety valve: The safety valve regulates the flow of gas to the oven. If it's faulty, the oven won't turn on. You'll need to hire a professional to repair or replace the safety valve.
Top 4 Reasons Oven Won't Turn On - Gas Range Troubleshooting (youtube.com)
