20 Most Recent eMachines ET1161-05 PC Desktop Questions & Answers
Marinaud corporation
got my phone back hunny xxxxx gia is back agan wraff
6/2/2017 8:19:35 PM • eMachines... • Answered on Jun 02, 2017
I need windows xp audio drivers for emachines
You can download the drivers from the following website
http://www.emachines.com/support/drivers.html
Select product category > desktop
Select product line > ET series
Select product model >1161
Select operating system > windows Vista
Download the audio drivers
Thanks for using fixya
proton
8/28/2015 3:22:55 AM • eMachines... • Answered on Aug 28, 2015
System restore and windows updates are not working can i fix this issue without reinstalling windows 7?
Is your Computer free of Malware ,etc , work on what you can clean off the Computer,as a !st try , see if it make a difference, last resort to reload Windows 7.
3/12/2015 8:11:19 PM • eMachines... • Answered on Mar 12, 2015
What System Restore not working. Gives a volume shadow copy timed out error when trying 2 create a restore point. if i try 2 update windows or create a system image it goes days not going anywhere.??
If system restore not working you can always try to do a repair operation with the disks that came with your machine. If you have no disks you are out of luck and will have to reload the machine with new software. If concerned about losing data/files you can remove the hard drive and install it as secondary on another working machine, download the files you want to a usb stick and reload the hard drive and re install the files you previously saved. Good luck
3/10/2015 4:52:45 PM • eMachines... • Answered on Mar 10, 2015
Computer wont turn on
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive power and data cables IDE SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical or fan lead can cause you problems
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat Thermal compound is a sticky paste that is placed directly onto the CPU. Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink. hope this helps
6/22/2014 8:26:41 PM • eMachines... • Answered on Jun 22, 2014
I need to set my audio up
Dear Allie, With my own setup, I had to buy a 2xmetre long cable with identical audio plugs at each end. One end plugs into the audio-out socket on my computer & the other plugs into the audio-in socket on my stereo. Hope this helps; if not please post more detailed information! 'b'ye!
4/28/2014 11:38:34 AM • eMachines... • Answered on Apr 28, 2014
Emachine ET1161-05 desktop...monitor keeps going
This may be something that Windows (or the computer is telling Windows) to do. Everyone wants to reduce the power consumption in the computer, so be default your monitor may be going into 'sleep' mode and turning off.
1) To change this, RIGHT click on the Windows desktop. 2) When the menu appears, select PROPERTIES, then select the SCREEN SAVER tab. 3) There are 2 things to check here. First at the top, make sure that your screen saver is selecting something beside BLANK. This will cause the monitor to blank out and appear to have turned off. 4) The second thing to check is the POWER settings. Click the POWER button at the bottom on the screen. 5) Now, you will see 2 rows of power options, one for when the computer is plugged in (which is all the time with your desktop) and the other is when on batteries. We're concerned with the PLUGGED IN settings. 6) Make sure the TURN OFF MONITOR setting is set for NEVER. This will ensure that your monitor never turns off on you. 7) Now click OK and OK and now your monitor shouldn't turn off on you.
Hope this response helps you out.
Best of luck!
I strive for '4 Thumbs Up'! If I've assisted you, I'd greatly appreciate you taking the time to provide me with a favorable rating. Thanks so much!
4/16/2014 1:11:32 AM • eMachines... • Answered on Apr 16, 2014
0answers
Et1161-05 emachine-cmos battery number
cr2032 just a plain watch battery
1/17/2014 8:08:50 PM • eMachines... • Answered on Jan 17, 2014
Cmoa battery number
cr2032 / just a plain old watch battery
1/17/2014 8:08:17 PM • eMachines... • Answered on Jan 17, 2014
Cmos battery number
It is probably best to remove the battery and look at it for the number.
1/16/2014 4:47:29 PM • eMachines... • Answered on Jan 16, 2014
Battery that controls the date and time when booting up
There is a 3.3 Volt button battery on your motherboard, that powers the BIOS chip so it can remember the current date and time. If you replace that battery then set the time and date the computer should no longer default back to 2008. To remove the battery press the small metal clip towards the edge of the battery, the battery will then pop out. Simply press the new battery into place. Make sure you are able to see the writing on the top of the battery for the correct polarity. If you attempt to do this yourself be sure to unplug the computer than press and hold the power button for about 4 seconds to de-energize the motherboard. Should you not feel comfortable doing this any repair shop should be able to do this repair while you wait as it takes generally less than 2 minutes.
1/15/2014 10:20:22 PM • eMachines... • Answered on Jan 15, 2014
E-machine et1161-05 won't boot
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Test all leads that attach to your hard drive power and data cables IDE SATA the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty Make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty. Computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error. Even something as small as a faulty electrical or fan lead can cause you problems Motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail. Check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in.
2/10/2013 7:56:01 PM • eMachines... • Answered on Feb 10, 2013
No signal to monitor
One bad or faulty lead connection can cause a computer to continue restarting on a cycle or to shutdown or fail to detect your hard drive
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps
11/21/2012 10:31:46 PM • eMachines... • Answered on Nov 21, 2012
EMachines ET1161-05 video crashes
There is something else wrong like bad RAM, or a failed CPU fan. Open it. Turn on and verify the CPU fan is running. If not fix the fan immediately before the CPU fry's.
10/10/2012 8:54:08 PM • eMachines... • Answered on Oct 10, 2012
Just trying to find out whether this computer will take a PCI sound card.
Hi, The this particular model of the computer has one spare PCI express slot , where an external audio card can be put in. Open the the system tower and look for an empty black slot on the motherboard.You can purchase a PCI express sound card .RegardsProton
10/4/2012 1:41:47 PM • eMachines... • Answered on Oct 04, 2012
eMachines ET1161-05 PC Desktop Logo
65 questions posted
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
E eMachines
  • E eMachines
Most Popular Question
et1161 05 emachine cmos battery number
  • Computers & Internet
