20 Most Recent
Orion HDLCDVD225 22 in. LCD TV Questions & Answers
Orion tv32RN10D Digital problems
factory reset hold volume button on tv down all the way while holding it down hold number 1 on your remote goes to stanby turn back on..
Can i get a stand fof my tv
Sansui tv's made for the USA by Orion have a customer service number on the back of the set. If you have one those sets, call the number and see if the stand is still available.
I hope this helps.
Bobya.
Can I hook a genie Wi-Fi camera up to this TV, ORION MODEL NO:TVDVD092
It's possible to connect a Wi-Fi security camera to a TV, but whether or not it will work with your specific TV model will depend on the capabilities of the TV and the camera. In general, most modern TVs have built-in Wi-Fi connectivity and support for applications like Netflix and Hulu, which allow you to stream video from the internet directly to your TV. However, not all TVs support all types of Wi-Fi cameras, and some cameras may require additional hardware or software in order to be used with a TV.
In order to connect a Wi-Fi security camera to your TV, you will need to check the specifications and compatibility of both the camera and the TV. If your TV has built-in Wi-Fi and support for streaming applications, it may be possible to connect the camera directly to the TV using the Wi-Fi network. Alternatively, you may be able to connect the camera to a computer or mobile device and then use an HDMI cable to connect the computer or mobile device to the TV.
In summary, it's possible to connect a Wi-Fi security camera to a TV, but whether or not it will work with your specific TV model will depend on the capabilities of the TV and the camera. It's best to check the specifications and compatibility of both the camera and the TV in order to determine the best way to connect them.
Can a wifi geeni camera be set up to my ORION MODEL NO:: TVDVD092
It is not possible to directly connect a Wi-Fi Geeni camera to an Orion TV model number TVDVD092. The Orion TV model you have mentioned is a television set that is not capable of connecting to a Wi-Fi network or functioning as a Wi-Fi network device. In order to use a Wi-Fi Geeni camera, you would need a device that is capable of connecting to a Wi-Fi network, such as a smartphone, tablet, or computer. You can then use the Geeni app on that device to set up and control the camera.
