20 Most Recent Orion1934 19" TV Questions & Answers
not worth buying a remote, you can use an rf converter or what i did was use an old DirecTV remote as i have several. on DTV remote, set selector switch located at top of remote all the way to the right to tv. Then hold down the select and mute button at the same time until the green light blinks 2 times, then enter one of these codes until the power button turns on the tv. Codes are as follows
10236 10463 11463 10179 11911
11929. Also verify that the tv input button does activate the aux channel. I knew these old remotes would come in handy some day.
Orion1934 19" TV | Answered on May 04, 2019
I have a Magnavox mc345 mote to program it to a orion tv this model
Orion1934 19" TV | Answered on Nov 25, 2018
try these codes for the orion tv:0121,0135 or 0035. good luck
Orion1934 19" TV | Answered on Nov 03, 2017
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Orion1934 19" TV | Answered on Oct 01, 2016
Yes. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
Orion1934 19" TV | Answered on Sep 25, 2016
Use the color control to adjust it.
Orion1934 19" TV | Answered on Feb 07, 2016
Without a remote control, you can't. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Visit some online sites too, which deals with electronic spare parts.
Orion1934 19" TV | Answered on Nov 24, 2015
what kind of schematic are you looking for? I did find this one here but i don't know if it is what your looking for. try this website:
http://www.nodevice.com/manual/sharp/70ES04S_CD_GBpdf/get42400.html#
it is a circuit diagram hope it helps you out
Tom
Orion1934 19" TV | Answered on Nov 08, 2015
Contact the authorized service center for Krystel at your town. Even, they can't provide you such a code, I'm sure.
Orion1934 19" TV | Answered on Jun 22, 2015
Type in the "brand name only" of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Orion1934 19" TV | Answered on Mar 18, 2015
In the menu, find antenna/cable. Locate cable and program from there.
Orion1934 19" TV | Answered on Jan 13, 2015
If you have the original remote, or a universal remote with number buttons that show up on the screen, you can call the cutomer service number on the set for help deactivating the v-chip.
Orion1934 19" TV | Answered on Apr 19, 2014
Orion1934 19" TV Logo
352 questions posted
Top Orion Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Orion Televison & Video
Most Popular Question
sharp tv 29v j200s schematic diagram
  • Televison & Video
