20 Most Recent Orion TVDVD092 9 in. TV/DVD Combo Questions & Answers
DVD INCORRET DISC READ
The particular dvd disc was not properly written or it has been locked to work on some set of particular devices mostly done to work only on the system it was written from or on.
Sorry about that but it is good to tell you that your player is okay.
Cheers. Remember to rate this solution.
cheers.
6/30/2018 8:40:43 PM • Orion TVDVD092 9... • Answered on Jun 30, 2018
How to set it up to universal remote
All the universal remote controls that I've had have come with a fairly comprehensive set of control codes for various appliances. If you don't have the manual you'll have to search online for a pdf relating to your universal which contains these codes.
6/29/2015 10:50:05 PM • Orion TVDVD092 9... • Answered on Jun 29, 2015
Not detect dvd
In this case is likely that the optical pickup in the player is either dirty or bad.
5/29/2012 3:23:31 PM • Orion TVDVD092 9... • Answered on May 29, 2012
The only functions the original remote for my Orion TVDVD092 performs is to turn the power on or off ocassionally. Is the proble with the remote or the sensor?
If the remote does even one function the receiver in the set is not the problem. It is possible if the remote is designed to program to another unit you have it in the wrong mode TV or Vcr or something other than your set.
5/25/2012 8:05:01 PM • Orion TVDVD092 9... • Answered on May 25, 2012
Reads dvd cleaner but incorret disc when plays movies
Check with an other disc. If the video format doesn't match this type of fault can occur.
4/30/2012 9:30:02 PM • Orion TVDVD092 9... • Answered on Apr 30, 2012
How to program tvdvd092 without a remote
cannot be done---all essential controls are in the remote.
3/26/2012 2:00:25 AM • Orion TVDVD092 9... • Answered on Mar 26, 2012
Does anyone know if there
Yes! there is a fuse located inside the set on the main board, make sure your the set is unplugged before you remove the back cover, next follow the 12volt line cord to the main circuit board, there should be a small gma glass fuse right where the wire is. Check the polarity of the 12volt cord to make sure it will work.
12/19/2010 11:00:58 PM • Orion TVDVD092 9... • Answered on Dec 19, 2010
Orion Model TVDV D092
Please try and use your AV input or play the DVD inthe combo to see if there is a perrfect picture.
If so the Tuner module is faulty and may need a replacement.
This can be confirmed if you can take a final voltage check to see if the tunerr receives the +12 necessary for the functioning . If not the regulator can be faulty.
The tuner must be replaced with the same type pin configutation , must be taklen out of the board witth good carre so as not to damage the PCB and resoldered.
make sure your cable input lines are good and there is no short in the splitters coming to your house in case your are using community cable.
9/14/2010 2:50:19 AM • Orion TVDVD092 9... • Answered on Sep 14, 2010
I have a TVDVD092 and have misplaced the cigar
Hi
A 5amp fuse should be ok in the 12v adapter if you are bying a new lead make certain you by the correct one as some leads have the center pin + and some have center pin - look on the set by the power input plug to find out the one you require, regards windyhouse
5/17/2010 10:04:17 PM • Orion TVDVD092 9... • Answered on May 17, 2010
2answers
No sound output
Besides checking to see if its has been muted witch is the obvious, I would strongly feel that this is the Amp inside the tv that has the issue. Things to check to see if its that amp are:
1.Try a tape
2.Hook up a dvd player and try that
3. some of these have headphone jacks try plugging in some headphones.
If you hear no sound in these circumstances then you have a amp that has blown. To fix a amp would be around $70 bucks for the part and labor? Well you see where its going and that is to the bank, most people would just have bought a new tv at this point.
Please be considerate when pressing the accept button that:
1. I have not personally touched you tv
2. I have not opened it up
3. I can only give a basic diagnostic based on what your telling me.
4. You tv cannot be fixed over email if its a hardware issue
Again thanks for your visit here at fixya.com and the accept button is only for my efforts!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
4/14/2010 3:13:48 PM • Orion TVDVD092 9... • Answered on Apr 14, 2010
I HAVE A ALL IN ONE COMBO DVD PLAYER/TV AND IAM GETTING INCORREC
System is telling you that you have a bootleged Disc. and some will refuse to Play those disc they will say No Disc!
12/9/2009 3:23:54 PM • Orion TVDVD092 9... • Answered on Dec 09, 2009
Orion TVDVD092 9 in. TV/DVD Combo Logo
52 questions posted
Top Orion Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Orion Televison & Video
Most Popular Question
only functions original remote orion
  • Televison & Video
