20 Most Recent Orion STV2763 27" TV Questions & Answers
did you figure it out? i am trying to get my orion tv1333 to go into aux mode without a remote. thanks.
Orion STV2763... | Answered on Dec 17, 2017
The batteries in the remote may be weak. replace
The transmission window on the remote may be blocked, or the Infra-red diode may be inoperative. No digital signal is leaving the remote. The receiver window on the TV may be blocked, remove obstruction.
Differential test. Does another remote control the tv? If you don't have one remember that the app "Peel Remote" for your smartphone may be used. Does your remote work on other electronic devices? If either is no then that is where your first problem lies.
Orion STV2763... | Answered on Sep 17, 2017
It may be possible to access the menu by holding down both volume buttons for 10 seconds. If not you probobly need the remote.
Orion STV2763... | Answered on Mar 27, 2017
hi there, yes there are some adjustmet pods them, but make a mark on it before you adjust so that you can turn it back again in case you lost control of the adjustmet. ty
Orion STV2763... | Answered on Feb 25, 2015
this may help
Orion STV2763... | Answered on Jan 03, 2015
This sounds like theres a capacitor somewhere in the vertical sweep circuit. You can replace the capacitor if you have a soldering iron and some electronic experience on trouble shooting tv sets. It is most likely from what you described the capacitor off the high voltage transformer that supplys the b+ to the vertical output IC. A repair person should be able to give ya a ball park on the cost as Im thinking somewhere from 85 to 135 Bucks depending on if theres only one cap goiung bad or could be a couple or more starting to dry up. So its your ball now .. Do you wanna spend that much to repair the set Do you like the set? is the set over 3 to 5 years old? Its up to you. Good Luck
Orion STV2763... | Answered on May 30, 2014
I believe these were made by Samsung. You will need to search for a service manual for more specific information.
Orion STV2763... | Answered on May 16, 2014
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Orion STV2763... | Answered on Mar 28, 2014
Orion STV2763 27" TV Logo
257 questions posted
Top Orion Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Orion Televison & Video
Most Popular Question
need code remote control studio series
  • Televison & Video
