20 Most Recent Euro-Pro 373 Mechanical Sewing Machine Questions & Answers
Hi I have a Euro Pro 464xc sewing machine, bought
If you have thread loops on the underside of the fabric then the top thread is not under tension at all. If the bottom tension is loose, it will be looping on the top of the fabric.
So, raise the pressure foot, and rethread the top from the spool to the needle making sure you pull the thread into the tension device. To test, lower the pressure foot and tug the thread below the tension device, it should feel firm. Tension dial should be fine at 5 or between 4 -6.
Don't mess with the bobbin tension, it should not need to be altered.
If you manual does not mention oiling at all, then your machine probably has nylon gears and maybe an oiling wick that is topped up by the technician during service. If this is a top loading bobbin then you probably still can oil into the wick under the bobbin in the round bit that goes around (rotary hook), there might be a hole in the middle? If yes, just put a drop of oil into it AFTER BRUSHING OUT THE ROTARY HOOK AREA well. This is just as important as lint will dry up any lubrication in the machine, then matt into a felt and cause wear and malfuntioning.
The stitching issues sound more like threading problems. Here are my recommendations for good stitching. Good quality thread, keep it in sealed containers out of sun when not in use, it will dry out. Don't buy the cheap 5 rolls of black thread in the bargain bin, fine for hand sewing and tacking but won't do your machine any favours.
Clean the tension discs regularly, clean out the rotary hook regularly with a little brush and try to get the lint out of the machine, don't blow it further in with compressed air. Check your manual for how to clean the tension, on your machine (if the image above is correct) I can't see a tension dial. But normally, you turn tension to zero, then floss between the discs with a selvage edge of clean cotton waste fabric. Dye particles and lint from thread will shed and build up in the tension, causing issues. If your manual doesn't show you how to do this, then go back to your shop/dealer and ask them how to clean this part of your machine. Do it regularly, it really helps. And oil as per the manual (although it seems this doesn't apply for your machine). However, machine will need professional service regularly to address lubrication inside the workings so don't forget to take it in regularly for this.
Put a circular piece of felt on the thread spool holder so that the thread spool sits on this, it helps the thread spool to turn smoothly.
Change your needle every 4-6 sewing hours, right size and type for the project at hand. When you start a new project, put in a new needle. I can tell from the sound my machine makes if a needle has gone blunt. Have a selection of needles on hand so you aren't tempted to just use the one in the machine.
Take care when winding bobbins that you wind it smoothly and evenly across the whole bobbin, keep gentle tension onto the spool as the thread winds off to ensure this happens. Give the thread a nudge with your fingertip as it goes onto the bobbin so it winds top and bottom, not just in the middle.
Always cover your machine up when not in use, keep out of direct sunlight or damp. Put a piece of waste fabric under the pressure foot between it and the feed dogs when finished using it.
For good Sewing machine info on line I like www.sewing.about.com, there is good threading up, needle info and how to maintain the machine. Machines are all different but once youve mastered the basic funtionality and what parts do what, they all function in similar ways. The most important part is the needle, it does the sewing, everything behind it is just the machinery making it move.
11/29/2020 9:08:56 PM • Euro-Pro 373... • Answered on Nov 29, 2020
0answers
Will no pick up the bobbin thread
Try changing the needle Try rethreading the machine top and bobbin Make sure the bobbin is turned the correct way In the bobbin case It's possible that the machine needs to be checked for a timing problem
8/15/2013 4:22:25 PM • Euro-Pro 373... • Answered on Aug 15, 2013
Hi, I cannot get it
I have the very same problem. The thread is also hanging up in the spring loop. Major frustration!
7/13/2013 11:15:40 PM • Euro-Pro 373... • Answered on Jul 13, 2013
I HAVE A EURO SEWING MACHINE MODEL 373 IT WILL NOT SEW A STITCH
try these suggestionschange the needle Correct needle insertion is mandatory for proper use of your sewing machine. Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle. Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft). Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.try rethreading the machine top & bobbinmake sure the bobbin is not warped make sure the bobbin is wound correctly & inserted correctlyin the bobbin caseif none of these suggestions help,, then you might think about havingthe machine checked to see if there is something wrong inside the machine
6/11/2012 4:29:44 PM • Euro-Pro 373... • Answered on Jun 11, 2012
Omega model 373
It may be either or a combination of these two things.
Lint/Thread etc in top tension, for which this tutorial will be beneficial:
http://www.sendspace.com/pro/wt7kfh
....or....
Timing of Hook to Needle, for which this set of diagrams will be beneficial in general terms:
http://www.sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Hook%20Timing.htm
It may be necessary to then dig deeper, but further specific detail will depend on the level of detail you have required initially when posting the question.
In the event please use THIS LINK and ask for "Bargainbox"
We recommend a General Service every 12-24 months, just like your car needs tuning, no less this rather complex machine.
Cheers
Martyn Bargain Box Fabrics
10/25/2011 1:56:02 AM • Euro-Pro 373... • Answered on Oct 25, 2011
3answers
How do I keep bobbing thread from bunching on model 375?
upper part of machine not threaded correctly - no needle tension = bunching underneath
10/18/2011 5:40:57 AM • Euro-Pro 373... • Answered on Oct 18, 2011
This is a parts identification question. My
Possibilities are:
foot pressure adjustment
tension dial adjustment
stitch elongation
If you can already identify the tension adjustment dial and this device is above the pressure foot, then I would gess it is the first one, foot pressure adjustment.
Many models don't have this but it was standard for many years on all machines, allowing you to control the pressure of the foot onto the needle plate, something you need to vary if you are sewing very heavy coatings or very fine silks, sometimes you just need to finesse the pressure yourself.
8/21/2011 2:48:29 AM • Euro-Pro 373... • Answered on Aug 21, 2011
WHERE CAN i GET REPLACEMENT
Try Joann Fabrics.
http://www.joann.com
12/28/2010 12:56:54 AM • Euro-Pro 373... • Answered on Dec 28, 2010
I lost the clear Bobbin
try sewingpartsonline.com or ebay
11/27/2010 6:19:01 PM • Euro-Pro 373... • Answered on Nov 27, 2010
0answers
0answers
Euro-Pro 373 Mechanical Sewing Machine Logo
65 questions posted
Top Euro-Pro Sewing Machines Experts
Mike Cairns
Mike Cairns
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Euro-Pro Sewing Machines
Most Popular Question
  • Sewing Machines
