20 Most Recent
GE Monogram ZICS360NR Bottom Freezer Refrigerator Questions & Answers
Water leaking. Mongram zic[s]360 (frig on top,
Have the fridge pulled out and check behind it. I had same model and it was leaking into my walls/floor and caused thousands of dollars in damage to my kitchen. BLACK MOLS Covered my walls/cabinets and made me sick. Please be very careful with this excess water coming from this model. GE should recall it but will not unless forced. Not Cool.
I have ice on the
ther is not a diagram of what you want / and in the parts brake down it is a drawing and does not show the drain . but you will find it in the back of freezer under the evap coil . I use hot water and a turkey baster and clear the ice and force hot water down the drain . it shoud work . mm hope this helps .. feed back pls .. and if it keeps freezing you can add a drain heater . too correct problem .
GE Monogram bottom freezer
ck the drain in the back of freezer . it may be pluged and when it goes into defrost cycle you get about a cup of water on the floor . if there ice on bottom of freezer then the drain is iced over . some models require a drain heater to prevent this . mm hope this helps ..
Refrigerator and freezer not cooling at proper
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
rr
Water is leaking from somewhere,
Check the drain and put a thermometer in both ref and freezer
Ref should be 33 to 36
freezer 0 to 15
If it won't stay in this range replace the cold control
Different ranges cause water buildup.
I cannot remove evaporator panel due to one
When you try to remove the cover is that the only place it seems to be held on. I believe that screw just holds the cover in the sight hole. The screws that hold the panel on are usually along the sides. The panel may need to be slightly raised before it will come out. Also check for any screws along the bottom edge.
