20 Most Recent Kenmore Elite HE3 Steam 8676 Dryer Questions & Answers
What does the code f70 on a kenmore elite dryer
F70 is a "communications error" message and the first thing to check is loose wire connections.
If a loose connection is not found, the controller board will probably need to be replaced.
Please report back here what you find, OK?
7/6/2018 12:28:25 AM • Kenmore Elite... • Answered on Jul 06, 2018
Kenmore Elite He5 Steam-drum won't turn.
it is possible the drive belt has broken, this is normally the problem
2/3/2018 9:52:07 PM • Kenmore Elite... • Answered on Feb 03, 2018
How do I repair my dryer?
Hi Is two sample resolution: 1 the out taken pipe is clog 2 the limit cycle sensor is broken Clean pipe disconnect from dryer, open back dryer cover exchange the sensor.
10/16/2014 12:30:09 PM • Kenmore Elite... • Answered on Oct 16, 2014
0answers
0answers
No a kenmore 80 series dryer will not heat . if
The heating circuit is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The problem is very likely in the thermal cut-off and the high-limit thermostat located on the blower housing. The thermal cut-off blows when the high-limit thermostat fails and cuts power to the heating element. Both the thermal cut-off and the high-limit thermostat need to be replaced if the former is blown open. Click on the link below for the detailed instructions in troubleshooting this kind of problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
6/20/2012 8:42:18 AM • Kenmore Elite... • Answered on Jun 20, 2012
My dryer drum won't turn but the electrical panel is lighting up
it is most likely that the belt inside the back of the dryer is broken or loose.unplug the dryer and remove the back cover of the dryer. it should look something like this:3_8_2012_9_09_58_pm.pngalthough the is for a different make of dryer, it should be similar.
3/8/2012 9:12:30 PM • Kenmore Elite... • Answered on Mar 08, 2012
E1 error
The fault code E1 means the electronic control detected the thermistor is open. It's either the wire harness connecting the thermistor and electronic control is broken or the connection is loose or the thermistor is indeed open. Measure the resistance of the thermistor then refer to the temperature and resistance table for the normal thermistor resistance values. Click on the link below for the detailed troubleshooting procedure.
Troubleshooting Error Code E1 on Kenmore Elite and Whirlpool Duet Dryers
12/31/2010 3:18:56 PM • Kenmore Elite... • Answered on Dec 31, 2010
My Kenmore Elite HE3 Dryer is not drying.
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) - remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
NOTE: One item I failed to mention - Double check the input power for your dryer FIRST. You should have 220VAC at the receptacle and terminal block. The dryer will STILL tumble and the timer will still function with a portion of the input power missing as these circuits only require 110VAC. The heating circuits, however, require 220VAC to function. If one leg of the receptacle voltage is missing the dryer may exhibit "No Heat" like symptoms. This could also be an indication of a burned or failed power cord. Continuity checks performed with the dryer UNPLUGGED should indicate a short between the prong end of the cord and the respective lugs at the terminal block.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
9/30/2010 4:43:03 AM • Kenmore Elite... • Answered on Sep 30, 2010
My kenmore elite he3 is not turning on. the timer
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
6ter
9/30/2010 12:19:41 AM • Kenmore Elite... • Answered on Sep 30, 2010
Dryer makes a sound as if there's a marble loose
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
ghhgfhf
9/29/2010 10:56:15 PM • Kenmore Elite... • Answered on Sep 29, 2010
Won't start
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
6/4/2010 10:02:51 AM • Kenmore Elite... • Answered on Jun 04, 2010
2answers
Drum spins off center and clothes get stuck between drum and casing
If your clothes get marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.
Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it.
Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set.
Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
4/23/2024 11:52:33 AM • Kenmore Dryers • Answered 2 days ago
2answers
Trying to find out how much part #7 on the exploded view of the Kenmore elite electric dryer model 110.2808 is? It is a motor.
110.2808 is an incomplete model number. Motors are typically $140 to $180 USD https://www.easyapplianceparts.ca/PartInfo.aspx?inventory=334304&SourceCode=18 This is is a typical Kenmore model designation and is probably the matching washer to your dryer. Yours is missing 4 numbers. Label in the back, label on the door frame, mentioned on the manual.
Model # 11028081700 Official Kenmore Elite washer
https://www.google.com/search?q=Kenmore+elite+electric+dryer+110.2808 ..
2/23/2024 6:44:28 PM • Kenmore Dryers • Answered on Feb 23, 2024
Is it possible to reverse the direction that the door opens on Kenmore Elite Quietpak 4?
Yes, it looks like you can. Don't forget though that you have to get inside and move the door switch. https://www.google.com/search?q=Kenmore+Elite+Quietpak+4+reverse+door ..
1/26/2024 12:16:00 AM • Kenmore Dryers • Answered on Jan 26, 2024
Kenmore ELE-2406028 Laundry Dryer. Help with door switch replacement.
It is an easy enough job. The videos show how. The parts are here https://www.google.com/search?q=Kenmore+ELE-2406028+door+switch ..
1/2/2024 4:11:27 AM • Kenmore Dryers • Answered on Jan 02, 2024
8546206 tech sheet
What is the question? Do I have the tech sheet? Yes I do.
12/17/2023 6:48:07 PM • Kenmore Dryers • Answered on Dec 17, 2023
Looking for age of Kenmore gas dryer Model 110.77741600
The are various idea here.
I have model and serial #s for my washer/dryer. What year ...
iFixit https://www.ifixit.com > Answers > View > I+have+m... Apr 3, 2017 - I have a Kenmore washer and dryer. I have the model #s and serial numbers. I need to know what year ( how old are my appliances?) of the models. 4 answers · Top answer: Erin Morrissey , How to find out the manufacture date of a Kenmore washer or dryer by the ... How old is my dryer? - Kenmore 110 Series ... 2 answers Mar 11, 2022 How old is my kenmore washer/dryer combo? - iFixit 2 answers Aug 4, 2018 help me find out how old this washer is - iFixit 2 answers Sep 29, 2021 What is this dryer model number? - Kenmore Elite ... 2 answers Jul 18, 2016 More results from www.ifixit.com Missing: 110.77741600 ‎' Show results with: 110.77741600
Can you tell me the age of a dryer from the model or serial
JustAnswer https://www.justanswer.com > Appliance Repair May 19, 2023 - Can you tell me the age of a dryer from the model or serial # Kenmore 600. Model is 110 78652700 serial is - Answered by a verified ... 1 answer · Top answer: Good afternoon. My name is ***** ***** I'll be assisting you with your appliance today. Please ... Missing: 110.77741600 ‎' Show results with: 110.77741600
12/15/2023 2:51:24 AM • Kenmore Dryers • Answered on Dec 15, 2023
Kenmore Elite HE3 Steam 8676 Dryer Logo
Popular Tags
20 questions posted
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Dryers
  • Kenmore Dryers
Most Popular Question
e1 error
  • Dryers
