20 Most Recent
Polaroid FXM-3211C 32 in. LCD TV Questions & Answers
Polaroid fxm-3211c has picture but no sound
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
1/31/2015 2:59:04 AM •
Polaroid...
Answered
on Jan 31, 2015
No picture but have sound
Check and replace damaged component/s at its back-light section circuit. If back-light inverter is faulty, it might have to be replaced as card basis. Contact any service technician to get helped.
Gopakumar Gopalan Google
3/10/2014 6:23:56 AM •
Polaroid...
Answered
on Mar 10, 2014
No picture when turned on and a buzzing sound from
In many cases on this tv the problem can be electrolytic capacitors failing on the power supply PC board. this is located at the top of the assembly. Required good soldering techniques to repair. The last one I repaired also had two shorted transistors. If the caps are 10uF @ 450V. Check the transistors on the heat sync adjacent to the capacitors for possible short.
11/27/2010 7:01:32 PM •
Polaroid...
Answered
on Nov 27, 2010
When i turn on my TV no picutre but i hear this
Your
power supply board needs to be REPAIRED not REPLACED, replacing the board will just make the problem happen again in two years or less, if you can use a screwdriver you can send me the board and I will repair it for less than it would cost you to do it yourself ($50) with the correct components. Email for further instructions!
Cory Schindler
[email protected]
5/30/2010 6:20:31 PM •
Polaroid...
Answered
on May 30, 2010
Polaroid TV working with constant red flashing light
If your Polaroid Roku TV is working fine but the red light is continuously flashing, it could indicate an issue that may need attention. Here are some steps you can try to troubleshoot the problem:
- Power Cycle:
- Turn off the TV and unplug it from the power source.
- Wait for at least 5 minutes.
- Plug the TV back in and turn it on.
- Check Remote Control:
- Ensure that there are no stuck buttons on the remote control. Press each button to make sure they are not stuck in the pressed position.
- Update Firmware:
- Check if there is a firmware update available for your TV. You can usually find this information in the TV's settings menu.
- Reset to Factory Settings:
- Perform a factory reset on your TV. This will erase your settings, so be sure to back up any important information first.
- Check for Physical Obstructions:
- Make sure there are no physical obstructions around the TV, particularly around the infrared sensor on the TV and the remote control.
- Contact Customer Support:
- If the issue persists and your TV is still under warranty, consider contacting Polaroid customer support for assistance. They may be able to provide additional troubleshooting steps or offer a solution.
- Professional Repair:
- If the TV is no longer under warranty and the issue persists, it might be advisable to consult a professional technician or a TV repair service to diagnose and fix the problem.
Always refer to your TV's user manual for specific instructions related to your model. If none of the above steps resolve the issue, it's recommended to seek assistance from the manufacturer or a qualified technician for further diagnosis and repair.
12/27/2023 10:15:57 PM •
Polaroid...
Answered
on Dec 27, 2023
