20 Most Recent Element Electronics FLX3220F 32 in. LCD TV Questions & Answers
Tv goes off cant get it to come on
That problem is usually cause of faulty capacitors on the power supply board..Just follow this instruction to fix your TV..1. Open the back cover of your TV.2. Look at the power supply board..Its normally connected to the power cord..3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..5. Some of the capacitors not bulged so its better if have a capacitance meter
8/22/2016 12:22:55 AM • Element... • Answered on Aug 22, 2016
I have am Element TV no picture just sound. Please advise
Hi Vee Jay, No picture just sound means you are not able to see the picture because there is no back light. Inverter board is the culprit in most cases. Good luck.
10/9/2014 4:36:54 PM • Element... • Answered on Oct 09, 2014
What generic remote will work for Element TV FLX3220FA
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier. Or, do a search by type in the brand name of your device at its search box, and press "Enter". http://electrohelponline.blogspot.com/ Check this link too. http://remotesearch.blogspot.com/
6/17/2014 2:50:59 AM • Element... • Answered on Jun 17, 2014
WHY CANT I GET HD CHANNELS ON MY ELEMENT ELECTRONICS 32 IN HD TV
To get HD channels you need to have a cable/satellite box that can receive HD channels AND you have to connect that box to the TV with either an HDMI cable or component jacks. A normal cable/satellite box won't work; neither will a coax antenna cable or consolidated video (yellow RCA) plug. Hope this helps!
5/21/2014 2:44:00 AM • Element... • Answered on May 21, 2014
0answers
My remote broke a few yrs ago. I need the tv code
Sounds like a re-branded set. Sold under different name than original manufacturer.
1-800-comcast they will get you the code. If there is no code specified, they can walk you through the procedure to search a working code. I assume you do not have the pamphlet / instructions for that. If you have the code list thing, it should have the manual search procedure on it. Quite simple to do.
3/8/2012 7:04:12 PM • Element... • Answered on Mar 08, 2012
Element 32" TV. Power only for a few seconds, no audio.
Yes, look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc. http://en.wikipedia.org/wiki/Capacitor_plague
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=FLX3220F+
Please post back what you find.
9/4/2011 11:54:06 AM • Element... • Answered on Sep 04, 2011
2answers
I have an Element flat
Tv power supply board have problems and it shorting out,that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
8/2/2011 6:33:19 PM • Element... • Answered on Aug 02, 2011
I have lost my remote
You can buy the element remote control at the link below
http://www.replacementremotes.com/Element/Buy-NF026UD-TV-Remote-Control.html
7/14/2011 3:41:55 AM • Element... • Answered on Jul 14, 2011
2answers
What would cause the sound on a lcd hdtv 32 inch
What other device are you connecting to your tv and how are you connecting it?
If you connect via a single HDMI cable that may be causing your audio problem. Some Tv and STB have handshacking issues which can knock out audio and/or video. The only solution would be to replace the HDMI cable or switch to composite cables.
6/27/2011 2:14:50 PM • Element... • Answered on Jun 27, 2011
2answers
I have an Electron HDTV
Ur tv have a problems,with it power supply board.That the board where the power a/c cord plug into it.When can u spare about $100.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement,will solved this problems.
6/14/2011 1:24:46 AM • Element... • Answered on Jun 14, 2011
Element Electronics FLX3220F 32 in. LCD TV Logo
78 questions posted
Top Element Electronics Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Element Electronics Televison & Video
Most Popular Question
electron hdtv
  • Televison & Video
