20 Most Recent
Kenmore 700 6972 Dryer Questions & Answers
How to replace belt in 700 series
first step unplug the dryer.then pop the top of the dryer open by pulling it towards you and up,sometimes you have to pry it open with a flathead screw driver then remove the front of the dryer by removing the two quarter inch screws on the inside top of the front. then unplug the door switch it will be two wires attached to it.then pick up on the fron and remove.next remove the drumand place the new belt around the drum and install.then you will have to put the belt rubber side inwards on the motor pulley and the outside(non rubber)part of the belt needs to ride on the tensioner pully (little plastic wheel)spin drum clockwise to make sure tou have it alighned properly if it pops off try again untill you get it rite.Then reassemble and test.
Replace dryer cord
There should be a cover where the cable goes into. Look at your old dryer - notice where the red, black, white and green cables go to - they should be marked. Compare those to your new dryer. With the power cord unplugged from the wall, remove the cord from the old dryer and install on the new one. The cord should have terminals already installed - you will need a socket to remove the nut holdng the terminals down.
If the power cord is really old and the insulation cracks when you bend the cord, replace the cord.
Can't get the clips off the bottom of dryer even with putty knife
Why would you want too ? Did you break em? Just prise them off there if that is the case. They slide and lock into position and are not needed to be removed at any time unless they were broken because you forgot to lift the front before removing it. Cannot make that model number work.Their are basically 2 styles of this washer Filter on top or filter inside. Which is yours and what is wrong with the dryer ? If you need further help, reach me via phone at
https://www.6ya.com/expert/dan_73bbd84fe1d95b61
