20 Most Recent
Dictaphone 2740 Desktop Cassette Transcriber / Recorder Questions & Answers
Best dictaphone for conference Recording
Hello the Dictaphone 2740 does not have the option for telephone
record or conference recording you need the Model that is really similar to the
2740 the model is 2750 this model has telephone record option and conference
record capable.
Note: for telephone record you need to buy a separate
adaptor like this ECS-DPRC
Wont play cassette
Usually when this happens it is either the "Pinch Rollers" or the "Drive" motor, has failed. You need to get it looked at.
Just put in my first tape for the 2740. Even SLOW
Hello this transcriber is only a 4.8 Speed transcriber and the slide speed control is on the front of the unit if the cassette that you are trying is a Normal 4.8 speed and is not responding you need to send your unit for service you can try this place Send an email to
[email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Need manual for a used Dictaphone 2720
I tried searching for a free manual to download, but I could not find one. I can give you a link, but the manual is for sale. Please check the link below:
http://www.tvps.com/Products/Dictaphone-2720-Manual---Standard-Cassette-Dictator-Transcriber-Desktop__ECS-MANDI2720.aspx
I do apologize. I wanted to provide you a free manual, but this is what I've found.
Good luck and have a great day!
NECESITO DIAGRAMA PARA DICTAPHONE 2750 DESKTOP
Hola en realidad no tengo el diagrama pero you te recomiendo que verifique la tableta pricipal por la parte posterior normal mente es muy comun una de las venas del trasistor se fracture observe cuidadosa mente por la fractura ya que si no te equivocaste al conectar el motor no creo que este danado el trasistor recuerda que el Modelo 2740 su motor es de 4 terminales la primera de lado izquierdo es negativo despues positivo sige A y despues B qae estos dos ultimos son para resitencia de velocidad variable 20K
Dictaphone MicWiz
Catherine, did you ever get an answer for your problem with MicWiz? I am a transcriptionist that works from home and they are having problems getting it to recognize my foot pedal (as well as another MT) with the new software. It is recognized by Express Scribe and ever other system we use, but not Merge.
Thank you,
Cindy
Dictaphone Expresswriter 2740 Tape Won't Move
The problem is with the capstan motor. More than likely it has developed a 'flat spot' and won't spin up. The clicking noise you hear is the solenoids trying to pull the heads into place, but because the motor isn't turning, it can't pull the heads into place.
