20 Most Recent Dictaphone 2750 Desktop Cassette Transcriber / Recorder Questions & Answers
Hello make sure that your cassette don't have a broken tab on bottom of tape if tabs are Ok send your unit to adjust the procttioon record Switch you can send your unit,Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Dictaphone 2750... | Answered on Oct 29, 2010
Can't you simply take the tape from the 2750 and put it into the other Dictaphone to play it? Or is the other Dictaphone a different size tape (eg; mini or micro)?
Dictaphone 2750... | Answered on Sep 01, 2010
Make sure the foot pedal is plugged into the SIDE of the machine and not the BACK of the machine. I've seen many people make this mistake...
Dictaphone 2750... | Answered on Jun 18, 2010
Sorry, I don't speak spanish, but try replacing Q609 on the main PCB. It's located on the top, towards the front of the machine.
Also make sure that the motor doesn't have a 'flat spot' (that it stalls). This is generally what blows the Q609 transistor. If you have power to the machine and a cassette in, try manually turning the motor to see if it'll start on it's own.
Dictaphone 2750... | Answered on Jun 07, 2010
Hello you will need and phone recor adaptor I recomend to used http://www.tvps.com/Products/1ECS-DUPR-Telephone-Record-Adapter---New__ECS-DUPR.aspx when your are ready just press and hold for 2 seconds telephone record button on your Dictaphone 2750 when your listen to your voicemail.
Dictaphone 2750... | Answered on Apr 25, 2010
Make sure the cassette protection Tab on the bottom is not broken if the cassette is not broken you need to send the unit for service Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Dictaphone 2750... | Answered on Apr 03, 2010
Hola Soy Tecnico en servicio de SONY y Dictaphone Y estas en lo correcto el modelo de Dictaphone 2750 Stadard cassette uno de sus problemas es que si la unidad queda con el cassette dentro y sin seleccionar auto encendido el motor queda funcionando asi que se muere mas rapido la verdad es que necesitas remplazar el motor y el motor solo tine dos cables asi que no es mayor problema el remplazarlo te puedo dar un correo para que solicites el motor normalmente esta compania no vende partes solo da el servicio de reparacion de las maquinas pero puedes decirles que Javier te recomendo para comprar estos motores que nececitas, despues de remplazarlo tus maquinas quedaran bien otraves email to service@tvps.com
Dictaphone 2750... | Answered on Dec 08, 2009
For transcribing, you'll need the machine (2750), the power supply, a foot control, and a headset (unless you use the machine's built-in speaker).
For dictating, you'll need the machine (2750), the power supply, and the microphone.
Dictaphone 2750... | Answered on Mar 16, 2009
There are several Freeware Text-to-Speech and some very expensive Text-to-Speech available on the internet, but to the best of my knowledge there is nothing available at any price that will do a proper job --the easy way.
This is why all "books on tape" or CD or whatever else, are performed by real people. Check in your local library. :-)
If you really want to voice record text books for your son to listen to, you are the only one who can do it. It is a labor of love. Or you can hire a student radio announcer.
At your local second hand stores you'll be able to get yourself a decent cassette tape recorder/player and a decent plug-in external microphone, with an ON-OFF switch. That should be an investment of not more than $20.00 to $30.00
The 60 minute cassette tapes are the more durable ones, and can be had for about $1.00 each.
Much information is available on the Internet about how to record your voice on tape.
For converting your tapes to MP3, my choice is a freeware named Audacity.
The benefit of this software is that not only it has professional features, but it has excellent on-line manuals and step-by-step instructions.
After that, it is only a question of trial-and-error until you are happy with the final outcome.
It is time and effort well invested.
Cheers
Dictaphone Audio... | Answered on Dec 22, 2014
There is a couple reasons way your unit can beep.
#1 not tape on the unit
#2 if you trying to record maybe the cassette tab on the cassette is broken to protect a recording
#3 it can be at the end of the tape
#4 try to play and make sure tape moves if tape don't move possible broken belt or bad motor
If none above you can send an email to service@tvps.com or call (805) 644-9525. Please indicate model and detailed description of problem.
Dictaphone Audio... | Answered on May 08, 2014
Hello they have it
http://www.tvps.com/Products/Dictaphone-1253-Manual---Mini-Cassette-Portable-Dictation-Recorder__ECS-MANDI1253.aspx
Dictaphone 2750 Desktop Cassette Transcriber / Recorder Logo
Popular Tags
10 questions posted
Top Dictaphone Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Allison
Steve Allison
Are you a Dictaphone Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Dictaphone Audio Players & Recorders
Most Popular Question
want transfer files recorded
  • Audio Players & Recorders
