20 Most Recent
AMD Sempron 2800, 2.0 GHz 2800+ (SDC2800DUT3D) OEM / Unboxed Processor Questions & Answers
I am running a AMD Sempron 2800+ 2.00 ghz 448MB
Methinks your RAM (488MB) may be the problem!
ONLINE your RAM loads-up then get's lost along the way trying it's best to deal with SO much data ~ trying it's best to deliver NOW! Plus memory and CPU required to access Internet (modem-cable or x) AND all of the negotiations THAT takes!
FROM DISK the CPU and RAM "call-up" data "as needed"... hence, no/less tossing of cookies.
Anthony
I cant find the right
Your problem is not related to your processor. You need to identify the manufacturer and the type of your network card and search the drivers
or,
if the lan card is integrated with the mainboard, go to the mainboard manufacturer's site and download the driver from their support/downloads page.
I have no sound on
You have to tell us what motherboard do you have in order to get the correct audio drivers
My computer does not have
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
If your computer came with a motherboard disc the drivers could be on it
Want to make sure your drivers are in place and no errors have occurred? Simply click start right click on my computer select properties then select device manager scroll to Display Adapters and click on the small "+" you should see the model of your PCI Express graphic card there. If there is a problem with it, a yellow exclamation mark should appear besides it. If you don't see it everything is OK and your card is working properly. Hope this helps don't forget to vote
Instaled win 7 and work
You need to install audio drivers for it to work. Go to the manufactures website and download drivers for your pc model. You can download it for free. Install the audio driver and it will work fine after the installation.
My pc no have sound driver
You need to find the make/model of your PC. Once you have done this, goto the manufacturer's website and install the latest driver for the sound card inside your computer. If that doesn't work, there are two steps you can take to update your sound card.
1) Goto Start > Control Panel > Device Manager > Sound, Video, and Game Controllers. You should see your Sound Card on this list. If it's not there, goto View and click on Show Hidden Devices. Look at what kind of sound card you have and head to the website to update the Drivers. If it's not in your Device Manager, open up your computer and look on the sound card for a manufacturer name and model. Once you have that, goto the manufacturer's website and install the latest drivers.
If you don't know what to look for, or if you've never opened up your computer before, take it to a computer technician and have them take a look for you. Remember to ground yourself before touching anything inside your computer. If you are not grounded you could very well blow out a vital piece of the computer's hardware.
