20 Most Recent
AMD Athlon 64 X2 3800+ Dual Core Processor - Socket 939 (AMDX23800) Questions & Answers
Dear sir, my motherboard is amd athlon 64 socket
It sounds like the cpu's temperature is raising over the safety level set in the bios so it switches off and displays the error!
to solve this either:
Your cpu cooler fan needs replacing
or
Your current cooler fan isn't connected to the correct socket on your board (check you're user manual, usually a .pdf you can download from manufacturers site)
or
Just try connecting your current cooler fan to the cpu and see if it turns on at all. If not make sure you replace it with one that is compatible with your system that can fit in your case
If the temperature has raised to a significant level the thermal paste could probably use replacing also, so get some thermal paste remover and thermal paste, and read in your motherboard user manual how to replace the cpu heat sink safely.
How to remove the AMD athlon 64x2 3800+
This is a very simple procedure.When you have opened the case you will see the CPU cooling fan on top of the CPU. It is held on by two clips which fasten at the sides of the fan radiator, onto a clip which is fastened to the motherboard.The clips are removed by turning the retaining clips to a loose position and then easing the clips from the securing lugs on the motherboard cradle. The cooling radiator may be stuck to the top of the CPU due to the heatsink compound used in the original fitting. If that is the case gently but firmly rotate the radiator in a clockwise and then an anti-clockwise movement until you feel the adhesion get loose. DO NOT try pulling the radiator upwards until you can feel no resistance.The radiator should then pull away from the CPU easily. This will reveal the CPU beneath. Release the CPU retaining lever at the side of the CPU until it is vertical to the motherboard. The CPU can be lifted from it's carrier. Be aware that the CPU has small pins which locate into it's carrier in a specific way. Refer to the CPU documentation as to how to refit it. Although CPUs are susceptible to static, placing it onto a piece of aluminium foil or conductive plastic will protect it.
How do i find my bios
It should be noted during initial boot. Look for a F key, Esc, even Del. to press. gl
VGA driver...
Is it a Jetway M26GT3-SVP motherboard? if you are using the onboard video (video from motherboard) here is the link to the driver
http://216.185.128.200/temp/jetway0c/downloads/driver/mcp61_2kxp.rar
if you are using a Video card? what is its model ATI or Nvidia?
Have no sound and found the audio driver is
Have you tied this link:
http://support.amd.com/us/psearch/Pages/psearch.aspx?type=2.1%3b2.12&product=2.1.2&contentType=Tech+Download+Processor&ostype=&keywords=&items=20
Please let me know if this was helpful and if itsolved the problem and good luck..
