20 Most Recent
AMD eMachines Desktop System w/ 17'' CRT Display, 2.0 GHz Athlon 64 3000+ (W3400) Questions & Answers
Hey my emachine fan was
The full motherboard breakdown will be evident if the pc will not come out of the yellow standby light on the screen. The other symptoms here will be the pc may sound as though it is running. This is assuming the power supply has not partially blown. The CPU fan will be seen to be running, the hard drive and cd rom lights will be glowing, and the hard drive can be heard running. The obvious point will be that in these circumstances the pc will show no signs of a display on screen.
What will have happened here is that the motherboard processor socket will have become inoperable. This is a non repairable item, but means the motherboard must be replaced for an effective and full repair.
The cost of this may sound worse that it actually is. The High Street stores will quote you inflated repair figures, when in truth the repair can be carried out by you with my instructions in under and hour and with full effect.
DIRECTLY from my own searching for my problem, I found this WEBSITE
How to hook up the face plate of a emachine w3400
Look at the pinout of the Front Panel header, of the eMachine W3400's motherboard.
The plastic front of the computer is the Front Panel.
The area of pins on the motherboard, that the cables (Wires) from the Front Panel connect to,
is the Front Panel header.
The motherboard for an eMachines W3400 desktop computer is an MSI ms-7145
(Micro Star International)
Orient the motherboard in your view so that we are both looking at it the same way.
Processor to the Top, Ram Memory slots to the Right, white PCI slots (3) to the Bottom.
JFP1 is the Front Panel header.
(Junction Front Panel 1)
JFP1 is on the Bottom Right corner. There are two columns of pins arranged vertically.
(The JFP1 header runs parallel to the Right side of the motherboard)
The Left side column of the JFP1 header is numbered Odd.
Starting at the Top and going Down, the pins are numbered;
1, 3, 5, 7, and 9
The Right side column is numbered Even.
Starting at the Top and going Down, the pins are numbered:
2, 4, 6, and 8.
There is NO Pin 10
A) Pins 1 and 3 are for the HarDDrive Activity LED light. (HDD)
If the LED light is dim will operating switch the wires around
B) Pins 5 and 7 are for the Reset switch. (Reset button)
> IF Used
C) Pin 9 is Not used. (NC. No Connection)
D) Pins 2 and 4 are for the Power On LED light (If dim switch the wires around)
E) Pins 6 and 8 are for the Power On switch. (Power On button)
Trace the wires back to the Power On switch. Even if it means temporarily removing part of the Front Panel to see.
Same with the LED lights.
See which wires go to the Power On LED, and HDD Activity LED. (Harddrive Activity LED)
Follow the 3 wires, and tell me where they go to on the Front Panel.
USB port?
Memory Card Reader?
Firewire port? (a1394)
I AM TROUBLESHOOTING AN EMACHINE MODEL W3410 AMD
Almost always indicative of a RAM memory problem. Troubleshoot by removing 1 stick of memory and rebooting. Switch sticks to determine if either stick of memory is bad or a bad bank on the motherboard.
Before you diagnose the problem,
if the power light on the computer comes on, but you get no video or the monitor is powered on but goes into sleep mode then your video adapter on the computer is bad. this is a frequent occurance to the default onboard video adapters connected to the motherboard. you must purchase a pci or agp video card and install into the computer and this will solve your problem. hope this helps, please rate me thanks.
My crt desktop becme pink
hello.
if not notice yet that if you moved or agitate the crt vga cable it will fix the pink color.
you need to install a new fga cable.the current one is defective after a big time of moving.
How do i get the setup disc or dvds?
Found other question....
The setup dvd is usually made when U turn the pc on for the first time. The system will want U to make them them called Recovery disks (dvd's).
Must be used machine and needs some TLC.
After shutdown, unplugged, open case and vacuum or blow out dirt. Clean fans and gently push connections to insure good connections. Power up to make sure all fans are working. Unplug and reassemble.
Boot up and run Disk Cleanup, then Defrag. Run MSconfig - startup tab and uncheck everything. Reboot.
The only thing that will shut down pc is overheating. If confussed, go to control panel to power options and read options, set accordingly.
U can create recovery disk by following directions in the Help and Support section.
Good Luck
My computer is out of
You email address chnged where?
Remove firefox, In controlpanel goto Add remove programs and find mozilla firefox and remove, then download latest version from the internet and re-install, see if you have same problem.
Let me knw how you get if this does not work we can try a few other things.
Many Thanks
Want to install drivers of amd 3400+
http://www.emachines.com/support/product_support.html
Please go to this web page and download your drivers after putting in your pc information. Have any more problems, ask and I'll do what I can for you. :)
Emachine W3400/ front panel connections
they have to be plugged in horizontally although it is possible to plug them in vertically because the pins are evenly spaced either way. they are color coded just not like you would expect for example one plug has a green wire and a white wire the green side goes to the green pin and the white side goes to a green pin with a white cross you have to look close because there are several green pins which is what threw me off do this with all three plugs
Emachines T5254 won't boot up
no pal. do u have any antivirus......if not so what are u waiting for.Just install a powerfull antivirus..Just like KESPERSKY ANTIVIRUS.if every will get alright then inform me at my ID
[email protected]
Emachine W1135
when ur starting the tower and it light are on and ur fan there is no problem with the power supply, i think that u rily need a new motherboard because ur board will not boot on start up..
Trying to hook the motherboard back in
it varys on each machine , but on the mother board their is a group of pins stickin out one or 2 have jumpers leave them alone! go to the pins left bare their is minenute abreviations next to the pins they will giv you an idea of what 2 do ,also look for colour coding.
