20 Most Recent
AMD Athlon XP 2000+, 1.67 GHz Retail Processor Questions & Answers
Sound drivers
CPUs do not have drivers. They do not contain LAN, Audio, or Video components. These are part of the motherboard they are installed upon. You need to provide the
motherboard manufacturer, model number, and revision number, along with the specific Operating System you are running. We can then help you find the driver(s) you need.
Bios battery dead & no power for a week no
John,
You can easily replace the battery. Just take it off the mainboard, go to the nearest shop, buy new one and stick it back on the mainboard.
No need to replace anything else, only date and time might be messed up.
My HDD will going to
Hard
Disk upto 500GB capacity can be added to most of the PCs. As regards compatibility, first you have to check the motherboard for SATA Hard Disk interface as newer hard disks are SATA. Adding the hard disk has nothing to do with the processor. However, motherboard should have the connecting port/ option (such as SATA). Some motherboards support both IDE and SATA devices. Please check the motherboard for SATA Port. You may find the motherboard model/ system model and google a bit for its specification. (You have mentioned AMD Athlon XP 2000, which is the Processor not the motherboard)
If SATA is available on your motherboard, you may add Sata drives of 250-500-750GB drives according to you
requirements. Otherwise you have to look for IDE hard Disk.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
I dont have the driver
Log on to www.driversguide.com, you will be able to download for free any utility drivers of your choice.
If you have any problem with that call or mail me on
[email protected] or call +234-8023821869.
cheers
Engr. Adewumi I.O
I have lost my driver
You can download the device drivers for your computer from the motherboard manufacturer's WEB site.
I cannot give you the link to the motherboard manufacturer's WEB site because youhave not provided me with the details of the make and model of your motherboard.
I dont have any audio
Search DRIVER DOCTOR on google, then go for a trial version
it will search and install drivers automatically
Plz tell me how could
GO TO WINDOWS UPDATE ON WINDOWS XP IT WILL WORKS IF NEED DIRECT DOWNLOAD POST YOUR COMPUTER NAME? MODEL?
