20 Most Recent
Clarke Power Products WE6480 MIG95 Flux Wire Weld Questions & Answers
I have a clark 85en welder with gas,I cannot get
Vltage is too high and the feed is too fast. You need to balance yhe two. What is happening is the wire is stabbing the work and that creates a dead short causing the wire to burn back into the nozzle and wadding up and sticking to the tip.
Mig welder powers up but only clicks when trigger is squeezed
1] Remove the power cable from the power. (socket on the wall) remove the top cover there should be a fuse located on the wiring panel.
2] perform all your house keping- like, all plugs and socket are tight, the correct contact tip with the the right wire size, roller/s are also the correct ones for the wire size and are turning if they are turning but not feeding the wire, then, the rollers need to be tightend , get back to us.
I see spots after welding.
Tig is very brite.If your seeing spots I would try another hood for awhile.If the battery is to weak or you can't adjust up to shade 12 for tig it can be very hard on your eyes.I would try a regular hood on some scrap and see how that works.I couldn't change the battery in my hood so I just had to buy another one.One other thing check for leaks in your hood.You've already done that more than likely.
Do you need a cheater lens?
We6523 WANT WELD
Check thermal overload. Also make sure the ground clamp connection is sound.
Is there a connection for gas to mig weld on a
No. Not with the spool up on the gun. It is one of the few flux core specific welders. This is not to say you could not try. the hard part is the plumbing between the gun and the main box. If you can get that figured out it would otherwise be the same components as other MIG welders.
