20 Most Recent Clarke Power Products Clarke 130EN Mig 110 Volt Questions & Answers
It will not weld...............no zap at the tip!
trigger switch wires broken in the cable ground wire not connected to the job
11/23/2017 9:28:31 PM • Clarke Power... • Answered on Nov 23, 2017
2answers
Have Clarke MIG 130 EN. replace Power Cable Assembly 23000054
Your local welding supplier would be you first choice. you will be able to fit an alternative power cable, dosn't have to be Carke,
4/25/2013 4:20:14 AM • Clarke Power... • Answered on Apr 25, 2013
It willnot weld
if it is just not feeding wire, check the tension on feed wheel. Make sure it turns when trigger is pressed. Also make sure you have gas with solid wire. If you have cored wire gas is not needed.
1/17/2012 8:56:37 PM • Clarke Power... • Answered on Jan 17, 2012
My welder pops bad when
Increase Voltage.
11/29/2011 1:42:12 PM • Clarke Power... • Answered on Nov 29, 2011
Have a clarke 125en wire feed drive wheels are not
release the tension from the WFR, pull the trigger and check the shaft that the rollers are attached is spinning if yes then the woodruff key is either missing or broken if no then the drive motor needs looking at, the shaft may have broken further along. get an electrician to check it out.
11/29/2011 1:33:07 PM • Clarke Power... • Answered on Nov 29, 2011
Drive motor for hobart 125
Your Hobart has a Drive Motor Protection.The Drive motor protection circuit protects drive motor from overload. If drive motor becomes inoperative, release gun trigger and wait until protection circuit resets allowing drive motor to feed wire again. Or you can reset it manually by pressing the reset button located on the back welder. If these actions does not work then here's the part number for your motor:HOB 239696.Check our website for pricing you need to call since this is an old welder and pricing needs to be search at Hobart Co.http://www.praxairdirect.com/webapp/wcs/stores/servlet/TopCategories1_10152_10051_-1
11/21/2011 5:48:04 PM • Clarke Power... • Answered on Nov 21, 2011
Need to know how to
Hi:
Here's the link to the owner's manual. It is pretty simple to follow up steps.
http://www.clarkeservice.co.uk/manuals/mig_welders/mig110e-160en.pdf
Have a good day!
9/2/2011 3:41:21 PM • Clarke Power... • Answered on Sep 02, 2011
I have a Clarke MIG
Hi and welcome to FixYa, I am Kelly
You can get your manual here: Manual PN 6014530
Manual is 290 kb Manual says it is 230VAC?
You may have to call them via this contact data to get a 110V manual:
Clark Power Products, Inc. 10752 N. 89th Place, Suite 104. Scottsdale, AZ 85260.
Phone: (480) 661-8599. Fax: (480) 614-0125
email: [email protected]
Their 1-800 number stopped working in 2009 due to financial reasons.
Hopefully this will help you.
Thanks for choosing FixYa,
Kelly
7/14/2011 9:34:14 PM • Clarke Power... • Answered on Jul 14, 2011
I HAVE A CLARK 110 VOLT MIG WELDER IT IS THE
Tear it down JUST far enough to gain access to the switch,check for and correct :corrosion,rust,oil or grease buildup,and/or damaged contact(s) at that station. That doesn't work,replace the switching unit.
7/13/2011 9:19:26 PM • Clarke Power... • Answered on Jul 13, 2011
I need a new gun assembly. Thanks Mike
Hi:
To find replacement parts for this brand is not so easy, but here is the part number EM23000049
and here's the link to order it, hope they have it in stock:
http://weldingdirect.com/miggunclmigw.html
Good luck.
7/13/2011 2:20:22 AM • Clarke Power... • Answered on Jul 13, 2011
I have a Clarke Mig
Hi:
If you are in the USA, check WWW.Praxair.com for your nearest welding store they will help you, Praxair has more than 1000 retail stores in the USA.
If you can make the motor to work just by by-passing the switch then your problem relies on the gun switch, that's an easy fix.
Just an advice; stop buying clarks, it is pretty defficult to obtain speare parts. Lincoln, Miller, Hobart or any other american machine are easier to find parts and are pretty good welders.
6/26/2011 6:47:37 PM • Clarke Power... • Answered on Jun 26, 2011
0answers
I have a problem with
You can order it on-line. Follow the link below.
http://www.weldingdepot.com/clarke_mig_welders.html
If this was useful to you please vote. Thanks!
2/17/2011 3:26:23 AM • Clarke Power... • Answered on Feb 17, 2011
What mig welder would you I buy to restore a old
I always tell my customers that the best machine for a body shop is a millermatic 212 if you have 220V available if not, go to a Millermatic 211 this is one is a dual voltage unit 110V/220V. if you can afford it buy a spool gun SG100 for all aluminum parts, the machine will cost you 999.00 and the spool gun 215.00. Best investment ever for your shop.
1/13/2011 5:01:56 AM • Clarke Power... • Answered on Jan 13, 2011
Copper end of wand and
Melt?? well looks like you had a burnback problem. There are contact tips, nozzles and gun liner available. Go to your nearest welding shop and ask for them. Around 35 bucks for all three (if you need the gas mixer known also as tip holder add 10 buck more).
To avoid burnbacks, reduce your voltage or increase your wire speed.
1/12/2011 12:35:13 AM • Clarke Power... • Answered on Jan 12, 2011
3answers
I have a clarke 130en mig with gas and it will not weld
The most common problem is that people still try and run the welder with extension cords. 10 ft,25ft,50ft,100ft, these cords all drain and can't supply the energy needed as if you were to plug it straight into a wall outlet. well I don't have a plug outlet where my work is, I need a extention cord. The only solution for not having a handy outlet is a Generator. that will supply the necessary voltage needed to do the job. EXTENSION CORDS ARE A NO NO. also, always double check your ground.
Hope this was helpful, please post a rating good or bad, thank you.
8/28/2010 4:22:24 AM • Clarke Power... • Answered on Aug 28, 2010
What are the symptoms of te welder being too far
Irractic welding, hot leads, and voltage drops. You need to size your welding leads accordingly.
5/30/2010 2:27:54 PM • Clarke Power... • Answered on May 30, 2010
Where do i get clark mig welder parts 130 en
These guys claim to have parts. I too am looking. My Guess is that the welder itself is probably a generic one that gets many brands applied to it. Often is the case with tools these days.
http://www.htpweld.com/
4/26/2010 6:09:07 AM • Clarke Power... • Answered on Apr 26, 2010
Clarke Power Products Clarke 130EN Mig 110 Volt Logo
36 questions posted
Top Clarke Power Products Welding Tools Experts
ADMIN Andrew
ADMIN Andrew
littlewheel
Are you a Clarke Power Products Welding Tool Expert? Answer questions, earn points and help others
View Most Popular
  • Clarke Power Products Welding Tools
Most Popular Question
symptoms te welder being far
  • Welding Tools
