20 Most Recent
Clarke Power Products Mig/Fluxcore Only 95 110V Questions & Answers
I have a 130EN and need the complete gun and hose
Thank you for responding, I hope this solves your problem.
The best place to find parts for just about any piece of equipment is Grainger company. On the website several connection types (Hobart etc) are listed. TWECO parts are the most common for many brands therefore your gun is most likely TWECO. Grainger has extremely helpful staff and will sell you the right part. Thanks again, If I have helped please leave a good rating for me.
Hi; I need a torch liner and maybe a side panel
Well,I found the site for Clarke ....
http://www.clarkeusa.com/info.htm
That's the good news...The bad news is I was informed by some other weldors that Clarke may be in Chapter 11 ...I can't swear to that ,but contacting them hasn't been possible yet...so maybe.
Hope this helps others...check their site and try to contact them maybe they will get things straightened out.
Mig welder powers up but only clicks when trigger is squeezed
1] Remove the power cable from the power. (socket on the wall) remove the top cover there should be a fuse located on the wiring panel.
2] perform all your house keping- like, all plugs and socket are tight, the correct contact tip with the the right wire size, roller/s are also the correct ones for the wire size and are turning if they are turning but not feeding the wire, then, the rollers need to be tightend , get back to us.
I see spots after welding.
Tig is very brite.If your seeing spots I would try another hood for awhile.If the battery is to weak or you can't adjust up to shade 12 for tig it can be very hard on your eyes.I would try a regular hood on some scrap and see how that works.I couldn't change the battery in my hood so I just had to buy another one.One other thing check for leaks in your hood.You've already done that more than likely.
Do you need a cheater lens?
